I know that these are not Neutrik, but worth a look nonetheless:
http://www.newark.com/jsp/search/browse ... allpartial
special offer!
David Raehn
special offer!
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
Re: special offer!
Designed by Farnell. Offered by CPC in the U.K. The blokes on that side of the pond will need to ring in on the quality.
Re: special offer!
These look interesting considering they're a grub screw to hold the cable...
MULTICOMP SVP562N CONNECTOR, SPEAKER, JACK, 4POS
If I needed any more cabling I'd pick some up and let you know what they're like but I'm done until spring I reckon.
Re: special offer!
Two things.....sometimes these Neutrik knockoffs don't fit smoothly into the jacks. And the allen-head set screw would be a real pain if you had to do a quick fix. Neutrik uses a phillips head screw.88h88 wrote:These look interesting considering they're a grub screw to hold the cable...
Sometimes it is just best to buy the best. Think about it - you build what? 10 speaker cables? Two connectors each, $2 difference per connector - $40 bucks to have the best when you have spent thousands on your system? No brainer. Leave the junk for the amateurs.
- Hackomatic
Re: special offer!
+1Bruce Weldy wrote:sometimes these Neutrik knockoffs don't fit smoothly into the jacks . .
Had a guy use some of his own cables from Seismic Audio on some Sound Tech speakers at the radio station . . the Neutrik wannabe's completely trashed the REAL Neutrik Speakons on the speaker cabinet. I literally had to use Vise Grips to dislodge the cable connector and you can only imagine what was left of the cabinet connector.
Dave H
Re: special offer!
After using many cheap and expensive brands over the years and experiencing all the above issues people have had.....Amphenol for the win !!!!!!!!
http://www.amphenolaudio.com/Amphenol_S ... ctors.html
PulseMan
PulseMan
BUILT
8 T48's 24" 3015LF LOADED
2 WEDGEHORN 10 MKIV's
1 SLA PRO FOR CENTRE FILL
Like us on facebook
https://www.facebook.com/Pulse.Entertainment.SA
Like us on facebook
Re: special offer!
Cool! Aussie company made good. You can probably get the parts cheaper than we can here too.PulseMan wrote:After using many cheap and expensive brands over the years and experiencing all the above issues people have had.....Amphenol for the win !!!!!!!!
PulseMan
Apart from possible poor fitting with "clones", the ultimate answer is the stomp test. Stomp on it. With your foot. If it breaks it's NFG.
Because people will walk on them, drop cabs on them, use them as footholds to climb cabs, and handholds to move cabs. And if it doesn't pass the stomp test it simply won't stand daily usage.
Neutriks stand up to it.
Seems Amphenol does too.
Re: special offer!
I've used Amphenol connectors before, 1/4" and XLRs and they're genuinely excellent quality. The jacks in particular are superb and I favour them over any other brand I've tried.
David Raehn
Re: special offer!
WOW!
Just looked them up @ parts express. $3.92 here in the States.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
