Got a chance to devote a few cycles to working on Box 1 of 2 of the Omni 15 Tallboy in the 2-12" Configuration Project. And what a project it has been, wow. The product is starting to come together at last.
Fixed most of the errors and omissions noted in the previous post. This cabinet most definitely develops significant air pressure when driven at say 10V at 40 Hz: to prove that, just stick your hand into 1 of the 2 ports created by the restrictor plate. Quite the huff and puff, and while it may not blow the house down, it will sure enough rattle the walls and the things hanging on the walls. And that's with an amp of about 50 watts per channel. Can't wait to hear what it will do when adequately powered.
The Selenium D220Ti compression driver in use for high frequencies is wired "backwards," by the way, like many others. When signal hot is connected to the tab with the red dot, the driver is in reverse phase from the 3012LFs and the Alpha6A-CBMR. Having now tried it both ways, I like it better with all drivers in phase.
Does anyone have suggestions for the torque to be applied to the mounting bolts for the 3012LFs? I've been reluctant to apply too much gusto, but would sure like to get them to stop leaking completely. Right now leakage has been greatly reduced, but not eliminated. But the reduction has been enough to allow me to hear the HC23-25 horn leaking a little bit, so that's the next candidate for another layer of gasket tape. The rest of the box seems tight, at least to my ear. Maybe I'll get some of that tar-like stuff, have been relying on neoprene gasket tape to this point.
At this point the cab sounds very good, but I think there is improvement still to be made, primarily through fixing the remaining leaks. Once that has been done, and I've gotten the replacement IMM-6 mic, I'll re-run the tests and report the results here.
As promised, if anyone is still interested, here are some photographs of the inside of Box 1 of 2.
Omni 15 Tallboy in the 2-12" configuration at altitude
OK OK here's just the box:
And here is the low-pass filter connected to the woofers:
And here is the midrange bandpass filter with the midrange, kinda hard to see the filter board:
The high pass filter:
And for completeness, the next post will feature the kindly plain inside of the removable back access panel.
All the best
--aeolos
Well, either it will work, or it won't.
