yet another T48 and OT12 build thread.....
Re: yet another T48 and OT12 build thread.....
#106 Post by Tom Smit »
:loler:
David Raehn
#107 Post by David Raehn »
There were other people there..... However, this was the first time in recollection that a band was set up. They probably didn't know what to make of it. Must've 'looked loud'. :wall:
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
:noob:
David Raehn
#108 Post by David Raehn »
Good news! They want us to come back! I've got to get working on my omnitops now!
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
miked
#109 Post by miked »
draehn wrote:There were other people there..... However, this was the first time in recollection that a band was set up. They probably didn't know what to make of it. Must've 'looked loud'. :wall:
Mandatory must-post. First thing out of her mouth is... http://www.youtube.com/watch?v=W2hRApdLADA
David Raehn
#110 Post by David Raehn »
By the way, Here's a short clip of our lighting test after initial aiming. I own the sound equipment and a little lighting stuff. The lighting here is owned by the event organiser. When we team up every 6 weeks or so, there is fun to be had!
http://youtu.be/QQZypby6TTE
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
miked
#111 Post by miked »
draehn wrote:By the way, Here's a short clip of our lighting test after initial aiming. I own the sound equipment and a little lighting stuff. The lighting here is owned by the event organiser. When we team up every 6 weeks or so, there is fun to be had!
Wow, that's impressive! As I'm finding out, lighting is not cheap at ALL. That's quite a display you've got there. Moving head fixtures are the way to go. They are also the most expensive things out there. A smoke machine is something I really need to buy. Even cheap lights look much better w/a little smoke.
BTW, how do you control all that? I bought a USB/DMX interface from DMXKING.com and am using Freestyler with an old laptop. I've yet to actually program any scenes though. :oops: I just figured out how to build fixtures from the DMX profile sheet the fixture comes with, and how to control that fixture through Freestyler.
David Raehn
#112 Post by David Raehn »
Chauvet Obey 40. Extensively programmed.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
miked
#113 Post by miked »
I wanted to go with a USB interface b/c I won't have a dedicated light-person to run a hardware controller. Once I get some scenes built and some more hands-on experience under my belt I should be good to go. But if you have someone to run the board, a hardware controller is definitely the way to go.
David Raehn
#114 Post by David Raehn »
We have 4 positions filled under the scaffold right now( FOH sound, lighting, projection(graphics) and projection(lyrics/powerpoint). May add a 5th by spring to record the audio of the event. I need to add a second mixing desk for that though, and a good set of headphones. Add to that a videographer or two, and a couple of still photographers. It becomes an undertaking just to keep everyone fed.....
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
#115 Post by Tom Smit »
miked wrote: A smoke machine is something I really need to buy. Even cheap lights look much better w/a little smoke.
@ miked: a couple of threads about hazers here on the BFM site...
http://billfitzmaurice.info/forum/viewt ... er#p172097
http://billfitzmaurice.info/forum/viewt ... er#p176619
miked
#116 Post by miked »
Thanks, Tom. Appreciate the info.
David Raehn
#117 Post by David Raehn »
Back on track. No drivers yet but I had to put the boxes together before the wood warped.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
David Raehn
#118 Post by David Raehn »
Slower progress than I'd like, but progress nonetheless....
I had heard about troubles with cutting the trapezoids so I approached them with a little trepidation. 10 minutes later with the bandsaw all were done perfectly. I let gravity clamp them in place and had pleasing results.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
miked
#119 Post by miked »
That brick idea is simply brilliant. Why do I learn about the easy way to do things after I've already built my cabs? :wall:
Glad to see you've gotten started on the OTops. Looking forward to more pics. What drivers are you using?
David Raehn
#120 Post by David Raehn »
I'll use the same 12A woofers you did, but I'm going to try my hand at the NSDs. :fingers:
I don't see any build threads for them anyway. :(
Once I cutlist the 1/4" BB, I'll probably Amazon the amount I need.
I'm trying to plan this stuff out very carefully because I'd like to repeat the entire build next year. I figure once I'm up to 8 + 8, I can rest a little while until things get big enough for DR300s and T60s. :)
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
