New member
arrie
New member
#1 Post by arrie »
hi everybody, i am Arrie from South Africa.
i have been following this forum for quite a while now and i even bought a few plans from Bill.
i have build numerous cabinets in the past and will still keep on building many more. i have my own rig which i utilise for mainly outdoor events.(EAW BH 882's)will send some pics soon. i need some advise with the T48 build i am planning, and that is can someone advise me on the maximum outside width for a double 15. if i understand the plans correctly it is 36" max, is that correct?
Re: New member
#2 Post by Chris_Allen »
Hi Arrie, welcome aboard!
You can go 36" with just one 3015LF for maximum performance at 40Hz out of one cab. If you can lug round such a big cab, it will be the most efficient and cost effective method of getting output.
arrie
Re: New member
#3 Post by arrie »
Thanks Chris
it is quite interesting, especially the 40 - 60Hz region. to me that makes the bigger cab with a single driver all the worth while. i do not have any problem with size or weight for that matter. i am currently busy building an enclosed trailer specially for transporting sound equipment.
i am absolutely crazy about the intimidating appearance of a big rig, but it should obviously sound that way too.
Re: New member
#4 Post by Grant Bunter »
G'day arrie,
Welcome to the forum :)
Re: New member
#5 Post by Tom Smit »
Welcome to the forum, Arrie.
I have an uncle with the same name. :)
