Brace cutting epiphany
jimbo7
#1 Post by jimbo7 »
I don't know 'bout ya'll, but cutting braces has been a slow and tedious process for me. Because of slight warpage in some areas or imprecise cuts, I've had to do a lotta sanding to get them to fit tightly. And some extra glue/screws here and there.....
My "bolt-of lightning" idea was this: Cut 2 braces at the same time. I screwed the wood together and then made my cuts. This resulted in 2 identical braces without the need to sand. I wish I thought of that sooner. Now I wonder if I can use this for other things..........
Not sure if anyone has done this or has a better solution. I just thought I'd share. (BTW I'm working on a t24. Should be done in the next couple days.)
escapemcp
Re: Brace cutting epiphany
#2 Post by escapemcp »
jimbo7 wrote:Cut 2 braces at the same time.
I use the router with the flush trim bit to duplicate my braces. You just have to get one bang one and you can quickly copy the rest. I will admit that when I first realized this I had a similar epiphany! :idea: :!:
#3 Post by Grant Bunter »
Be careful just how tight you make your braces.
When it comes to adding another panel is when you realise they were to tight...
koturban
#4 Post by koturban »
You might try double sided tape instead of screws.
Carpet tape is strongest.
#5 Post by Radian »
I use the original layout lines on the first panel, project everything up with a framing square, then use screws.
Pretty bitchin' to watch a warped panel get pulled straight into position by a brace.
"I love the framing square."
Titanium Hand
#6 Post by Titanium Hand »
Braces :noob:
Can't live with them, can't live without them!
I'm with Grant and Escapemcp.
I warped the crap out of the bottom panel on one of my T39's by pushing a brace in too far :wall:
Flush Trim Bit / Pattern Making Bit ; on the router are the greatest assistance fullstop in duplicating Braces or any other components TBH. I won't build ANYTHING now without my router
