First: I am using 5.25 inch drivers that match my TLAH. I bought 30 of them (a while back) to get a deal on them (best buy I ever made) so I have lots left over from my TLAH build, and they happen to have the right specs since it matches the goldwood more or less and was 1/3 the cost.
Second: I modified the height to match the width of my TLAH (9 inches outer width, 8 inch internal).
The depth is 15 inches (like Bill's are) and the width of each driver facet has been adjusted to 6.5" roughly ending up with a 39.5 inch cabinet width.
The tweeters are front mounted and the woofers are rear mounted, recessed beautifully. The edges on the faces of the SLA look exceptionally accurate and will make for an easy glue joint.
For the record, this project gave my dad the opportunity to invest in a quality cross-cut jig for his table saw (previous one wobbled an unacceptable amount considering the precision required in making the baffle).
Now to the pictures: I trimmed the edges after this picture but the other picture turned out to be a blurry mess so here is the baffle standing on top of the table saw (not glued yet) Looking absolutely flush there I might say
 What will you power it with?
