Tuba 18...oops
Tuba 18...oops
Hey gang,
I am in the middle of building a tuba18 for a friend of mine since he loved how my tuba HT sounds. At any rate, I am talking som artistic license and building the unit with legs and hardwood banding on the plywood.
The problem is that I goofed up reading my cut list and ended up making the sides of the tuba too small. They are 1-16" too short which I'm not really worried about, but they are 3/4 inch too narrow. If I construct it with the remaining internal baffles all the same size, the width of each "tunnel" or baffle..not sure of the correct name, will be 3/8 narrower.
I'm worried that the proportional increase in size between each successive baffle will be thrown off and it won't sound as good as it should.
I'm I over thinking it? What would you advise? I can't make another pair of sides, I already banded them and mounted the legs to them. Should I just decrease the width of all the internal baffles?
Any help would be appreciated.
Re: Tuba 18...oops
50 some views and not a single idea?
Re: Tuba 18...oops
Bbieger wrote:50 some views and not a single idea?
A little better explanation maybe? You've attached the legs to the sides? That sounds like something you attach to the bottom. So, you might not be getting responses because it's a little confusing.
If it is the sides you are talking about - you are saying the the height is 1/16 too short? If so, not a real problem. If the depth of the panel (front to back) is 3/4 too short, then you may have a problem. The design of Bill's boxes are such that the side panels are carved in stone (especially the depth). The width of the cabinet is variable. 1/16 here and there won't make too big a difference - but 3/4 is quite a bit.
Why not just add a 3/4 strip to the back? Cut off the banding, add a strip, then re-band it?
Re: Tuba 18...oops
it really is a confusing explanation. pics woudl be helpful.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
Re: Tuba 18...oops
Thanks Bruce. That I what I was afraid of.
The side panels are where the problem lies. The depth (back to front) is where it is 3/4" too short. Sigh. I wish I had realized that the panels were cut to slim before I mounted the legs to them. Because I went with the widest design, I'm out of birch play.
The legs are actually not just mounted at the bottom. They will run full length from the top, and have a curved foot that extends outside the edge of the box. (Read lots of planning 4/4 stock, tedious pattern following router work, and biscuits.
I realize that I am probably coming across as a complete newb, but trust me, this thing will look terrific when I'm done with it. Such is the nature of wood working. It is indeed a subtractive art. Simple mistake not caught early. I'll find someway to correct it. Thanks for the info
Re: Tuba 18...oops
Bear with me, I'll post pictures in a minute.
Re: Tuba 18...oops
Here is a picture of the sides that I am talking about. Looking at the front of the sub, the width is fine, the height is only 1/16' too short but the depth of the sub (front to back) is 3/4" too narrow.
As you can see in the photo with the layout lines, I was using the original sizes of the internal parts.. but due to the fact that the panels are too narrow, the passage ways on the outer ring.. would be 3/8" too narrow on each side as the entire side piece is 3/4 too short.
My only thought is to reduce the size of all the internal components that establish the depth of the sub by 3/4"... those would be the horizontal layout lines in the photo.
Make sense?
The last photo is the media cabinet I made for the same friend. Different wood species (curly maple and bubbinga) as opposed to birch and sapelle on the sub. But I wanted to mimic the same style with the curved legs and opposing color woods.
Thanks for any input!!
Make sense?
Re: Tuba 18...oops
Since the die is cast that's all you can do.Bbieger wrote: My only thought is to reduce the size of all the internal components that establish the depth of the sub by 3/4"... those would be the horizontal layout lines in the photo.
Re: Tuba 18...oops
Thanks bill. You think that is going to really be a detriment to how the sub sounds? I realize that it's less than ideal and you can't imagine how angry at myself I am, but at this stage is it realy worth cutting the legs off, going to the hardwood store and starting all over?
Re: Tuba 18...oops
Compensate for it by going as wide as you can.Bbieger wrote:Thanks bill. You think that is going to really be a detriment to how the sub sounds? I realize that it's less than ideal and you can't imagine how angry at myself I am, but at this stage is it realy worth cutting the legs off, going to the hardwood store and starting all over?
Re: Tuba 18...oops
Roger that. It's 17" wide, which was the widest recommended for a single driver.
I'll guess we will see
Re: Tuba 18...oops
Beautiful work....
If it doesn't sound good, just sit and look at it!
Re: Tuba 18...oops
If you haven't cut them yet add another inch.Bbieger wrote:Roger that. It's 17" wide, which was the widest recommended for a single driver.
Re: Tuba 18...oops
Would you be able to sand the "trim" flat with the panel, and then use part of the "trim" as your panel? I realize that it probably wasn't what you had intended, but, ..... being as it's a piece of art, changes happen along the way.
Re: Tuba 18...oops
Hey Tom,
That was exactly the plan. The legs are actually flush with the other side of the panel.
I love building these things. I don't get to use my mammoth HOme theater tuba anymore as I moved out. It's huge and ugly as it sits behind the screen. Thinking of building one of the low profile ones and standing it on end in the corner. I don't like boxes though...thinking of how I could construct some kind of spiral out of veneer.
