TLAH for my HT Mains
MissileCrisis
Re: TLAH for my HT Mains
#16 Post by MissileCrisis »
Sanding is fun. Can't wait til I Deft these tonight.
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
MissileCrisis
#17 Post by MissileCrisis »
Ran into a hiccup, this isn't remotely airtight. (see corner) Any suggestions for how to make this airtight? I'd like to keep the back removable in case of driver failure. Things I have: lots of weatherstripping, PL, wood glue, duct tape, other miscellaneous stuff. The width is a fixed distance because the bottom is determining the width of the sides so no amount of sideways pressure will fix that...
Looking pretty good considering I did 75% of the work today.
Finish will have to wait til tomorrow, then it's driver wiring time (any suggestions for a quick way to test polarity, or rather a quick tutorial).
Thanks to a forum member who mentioned/showed using thin ply as a wiring board, only burned myself with the soldering iron twice.
2 x TLAH
SLA Center
1 x 212 TH (custom)
sine143
#18 Post by sine143 »
rotate one of your inductors so they are at 90 perpindicular to the board and the other conductor. helps eliminate interference between coils.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
MissileCrisis
#19 Post by MissileCrisis »
Considering the length of the wire is short as is (inductors) I'll see if that is possible.
2 x TLAH
SLA Center
1 x 212 TH (custom)
#20 Post by Grant Bunter »
MissileCrisis wrote:Considering the length of the wire is short as is (inductors) I'll see if that is possible.
Add some wire if needed to make that happen...
MissileCrisis
#21 Post by MissileCrisis »
*Will do.
2 x TLAH
SLA Center
1 x 212 TH (custom)
MissileCrisis
#22 Post by MissileCrisis »
Did what people said and rotated next door inductors. These things are works of art (IMO)
Putting on first coat
Sand between coats
2 x TLAH
SLA Center
1 x 212 TH (custom)
MissileCrisis
#23 Post by MissileCrisis »
Building this speaker I have broken: 1 tweeter, 1 sock, tbc....
Something things I have learned: soldering lots of tweeters is a PITA, remember to drill out the hole for the screw (goldwood tweeter), never work when you're in a bad mood.
Progress: working on mounting and soldering/ installing.
2 x TLAH
SLA Center
1 x 212 TH (custom)
#24 Post by DJPhatman »
MissileCrisis wrote:soldering lots of tweeters is a PITA,
+1
MissileCrisis wrote: remember to drill out the hole for the screw (goldwood tweeter),
MissileCrisis wrote:never work when you're in a bad mood.
-1 Woodworking, especially speaker building, should change that bad mood into a feeling of calm and relaxation!
:cowboy:
MissileCrisis
#25 Post by MissileCrisis »
Slow and painful:
2 x TLAH
SLA Center
1 x 212 TH (custom)
MissileCrisis
#26 Post by MissileCrisis »
:cowboy:
Meant to say: tired and frustrated -> bad mood.
Hopefully Leland can throw in some extra tweeters into my order, or else I won't have speakers for a long time, or I'll have to use the one who's frame I broke :(, hoping Leland checks his PM's regularly.
2 x TLAH
SLA Center
1 x 212 TH (custom)
#27 Post by AntonZ »
DJPhatman wrote:-1 Woodworking, especially speaker building, should change that bad mood into a feeling of calm and relaxation!
:cowboy:
That does not work for me, at least not always. Speaking for myself here, but I have learned from experience that whenever there is a grain of impatience in my bad mood, I should refrain from doing woodwork. Especially when nasty buggers like the table saw and router are involved. My impatience tends to lead to stupid mistakes which only reinforce the mood :chainsaw: Your mileage may vary.
#28 Post by DJPhatman »
Although my answer was meant as "tongue-in-cheek", my conveyance didn't come through. Apologies.
But, for me, when I could woodwork, it made me happy and relaxed. I didn't put pressure on myself to get any projects done. I just worked on them instead of watching TV, going to the bar (not always :wink: ), recreational stuff. I kept it a hobby. Since I can't woodwork anymore, I miss it very much. It is all in your perspective of woodworking. If you think of it as work, it is. If you enjoy it, you'll never work a day in your life.
#29 Post by LelandCrooks »
Done. Although emailing me is a much surer way to get my attention, or at least to make sure I get it done. Hard to keep track on stuff on the pm system, and my memory aint' what it used to be.
MissileCrisis
#30 Post by MissileCrisis »
LelandCrooks wrote:Done. Although emailing me is a much surer way to get my attention, or at least to make sure I get it done. Hard to keep track on stuff on the pm system, and my memory aint' what it used to be.
I must be blind but I couldn't find your contact email, thus the pm. Regardless you've provided nothing but class A service so thanks for being awesome.
2 x TLAH
SLA Center
1 x 212 TH (custom)
