Here is the build thread for a couple of T60's I built for a customer, who also happens to be a good friend.
Later we added more T60's and threw a desert party on some private land for about 100 people.... just to see if we could pull it off.
We are stoked on the results, and have been asked to do audio at more desert parties! Wooooo! Excellent fun.
Both sides marked out.
Drilling through to the second side.
Access cover.
Rounded both sides for the storage access.
The first difficult cut 54 degrees. I made a little jig
Baffles.
Cover for dust
Spacers glued & screwed
Pulling the t-nuts through.
T-nuts glued & screwed.
Made spacers to locate the braces.
Pocket screws hold braces in place.
Dry fit of panel 6.
Panel 6 complete.
Used my laser machine to cut a handle template.
This is Panel 7
Driver break in.
More Braces
I fill the pocket screws with PL as I go.
I used straps to square things a little during PL curing.
Made some braces. Staples and glue.
Panel 10. Couple of operations to carry out here. Wheels, connectors and handles.
1/10 braces.
Made a dowel piece for the handle
Rounded off the braces that you can see
Speakon holes
Pre-paint
Dry fit of second side.
Holes lined up!
Glued and screwed.
What the track saw was designed for.
Cat loved the T60's
All connectors tinned with solder.
Sanity check for polarity.
Rubber tube leak test - none found round the driver.
This is the removable access cover flange.
Final access cover on and another round of leak testing.
Extra material for the handles. Scraped the paint off to help it to stick.
Pretty much complete except for paint.
Official T60 service tool.
Couple of shots in primer complete except for Duratex.
