Hello From New Castle PA
Re: Hello From New Castle PA
#16 Post by LelandCrooks »
The flat pack is a separate item from the kits.
If you order the arrays prebuilt just put a message in the field you want switchable banks. I'll figure it out for the cab in question. You'll also need http://www.speakerhardware.com/dpdt-mini-switch.php which is not in the kits.
