miked wrote:Very, very nice!  They look fantastic...and a 5-hat award to go with it?  Sa-weeeet!
   I can really appreciate how tight your builds are; I hope to be that good one day.
I appreciate that - they aren't as perfect as I'd like 'em, but I try to balance my "anal" side against my "get the damn thing done" side.
Thanks for the pics of the access cover.  I wanted to use t-nuts/bolts for mine, but there's no way to recess the bolt heads with only 1/2" of material to work with...bolts would go right through the wood.  What type of screws did you use?  Are they the 1-inch, coarse thread screws?
My first ones have T-nuts and a phillips head screws that are countersunk.  That's how Leland's kits used to come.  Now, he's using a #10 screw that's 1.25" long (I think...may be #8 and 1"....didn't measure 'em, just used 'em).
Believe me the screws are much easier.  I used 12 on each cover.  Probably wouldn't hurt to use a couple more, but with a double layer of weatherstripping, I don't think they are going to leak.  And hey, if Leland says they are ok, who am I to argue?  He's built a hell of a lot more of these than I have.
BTW: Do your cabs have feet?
Yep - all my cabs have feet.  That way, they can walk themselves into the trailer.  At least that's how I'm trying to train 'em....ain't working to good yet.
 Will you v-plate the stack of four, or are you making another v-plate and then plating 2 pairs? Just thought I'd ask.
I hope some day to v-plate the whole stack - just because...  But, for the Concerts in the Park series this year, I'll be v-plating two on each side of the stage.  It's a wide stage and most of the crowd sits to the left and right.  I can get 'em split about 40 feet, and with a high pass of 50, I don't think I'll have too much of an issue.
And speaking of V-plates......
