THT LP build
Re: THT LP build
slinger wrote: Is my panel 2 being slightly higher than panel 4 (first pic) going to be a problem?
Drew
It shouldn't be a problem, but it appears that you didn't double check the measured length of panel 2 in place before cutting to final length.
slinger
Re: THT LP build
#17 Post by slinger »
You are correct Bill. I may trim the extra off once panel 4 is installed. Is there an easy way to make sure panel 4 is the correct height on the clamping side?
Thanks, Drew
slinger
Re: THT LP build
#18 Post by slinger »
Well panels 4 and 5 went on today with the help of my wife. I plan on doing panel 6 the baffle tomorrow. What is everyone using for epoxy?
koturban
Re: THT LP build
#19 Post by koturban »
I used the standard 5 minute epoxy.
Remember, don't mix more than you can use within its set time.
slinger
Re: THT LP build
#20 Post by slinger »
Well, panel 6 aka the baffle didn't go too well. I cut the whole a little big and I don't think there is enough wood left for the tee-nuts to grab on to. I will try again tomorrow.
Re: THT LP build
#21 Post by Tom Smit »
Bummer. :(
At least it wasn't permanent. You can always cut the old one to make braces. :)
slinger
Re: THT LP build
#22 Post by slinger »
Yes, the first one was just a little big so I figured I would trace the old whole with a sharpie then cut inside that line. Should I cut the whole on a 30-45 degree angle?
sine143
Re: THT LP build
#23 Post by sine143 »
you could always add/PL a slim piece of ply to the inside of the hole at every t nut....
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
koturban
Re: THT LP build
#24 Post by koturban »
slinger wrote:Yes, the first one was just a little big so I figured I would trace the old whole with a sharpie then cut inside that line. Should I cut the whole on a 30-45 degree angle?
If you're having trouble with the size, experiment with thin cardboard until you get the hole size right, then use it as a template.
I kept the hole as small as I could, and found no need to chamfer.
slinger
Re: THT LP build
#25 Post by slinger »
Yes, I may get a piece of cardboard to try to get size right.
slinger
Re: THT LP build
#26 Post by slinger »
I'm getting close to putting the braces in on the tht. How are they fastened in place. There are some that aren't going to be able to be screwed or brad nailed. Do I just put them in place and then rub pl premium all around the joints to attach them?
koturban
Re: THT LP build
#27 Post by koturban »
I'm assuming you are speaking of the parallel braces, and not the corner braces.
Run a bead down each edge and slide them in. Try not to touch either panel until you get close to where you want it. A brad nail or two to keep them in place while the glue sets. Since they are only for bracing, they don't need the same scrutiny for having airtight beads.
Re: THT LP build
#28 Post by Tom Smit »
koturban wrote:I'm assuming you are speaking of the parallel braces, and not the corner braces.
Also, if the cab is laying on it's side, you could put a temporary blocking to support the side of the brace that is opposite the outside, to that the brace will remain square to the panels.
slinger
Re: THT LP build
#29 Post by slinger »
Where should the braces go? Should they be lined up in a straight line or should they be staggered or does it matter? This is for the THT LP.
Thanks
koturban
Re: THT LP build
#30 Post by koturban »
"Staggered" with respect to....?
