It shouldn't be a problem, but it appears that you didn't double check the measured length of panel 2 in place before cutting to final length.slinger wrote: Is my panel 2 being slightly higher than panel 4 (first pic) going to be a problem?
Drew
THT LP build
Re: THT LP build
Re: THT LP build
You are correct Bill. I may trim the extra off once panel 4 is installed. Is there an easy way to make sure panel 4 is the correct height on the clamping side?
Thanks, Drew
Thanks, Drew
Re: THT LP build
Well panels 4 and 5 went on today with the help of my wife. I plan on doing panel 6 the baffle tomorrow. What is everyone using for epoxy?
Re: THT LP build
I used the standard 5 minute epoxy.
Remember, don't mix more than you can use within its set time.
Re: THT LP build
Well, panel 6 aka the baffle didn't go too well. I cut the whole a little big and I don't think there is enough wood left for the tee-nuts to grab on to. I will try again tomorrow.
Re: THT LP build
Bummer.
At least it wasn't permanent. You can always cut the old one to make braces.
Re: THT LP build
Yes, the first one was just a little big so I figured I would trace the old whole with a sharpie then cut inside that line. Should I cut the whole on a 30-45 degree angle?
Re: THT LP build
you could always add/PL a slim piece of ply to the inside of the hole at every t nut....
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
Re: THT LP build
If you're having trouble with the size, experiment with thin cardboard until you get the hole size right, then use it as a template.slinger wrote:Yes, the first one was just a little big so I figured I would trace the old whole with a sharpie then cut inside that line. Should I cut the whole on a 30-45 degree angle?
I kept the hole as small as I could, and found no need to chamfer.
Re: THT LP build
Yes, I may get a piece of cardboard to try to get size right.
Re: THT LP build
I'm getting close to putting the braces in on the tht. How are they fastened in place. There are some that aren't going to be able to be screwed or brad nailed. Do I just put them in place and then rub pl premium all around the joints to attach them?
Re: THT LP build
I'm assuming you are speaking of the parallel braces, and not the corner braces.
Run a bead down each edge and slide them in. Try not to touch either panel until you get close to where you want it. A brad nail or two to keep them in place while the glue sets. Since they are only for bracing, they don't need the same scrutiny for having airtight beads.
Re: THT LP build
Also, if the cab is laying on it's side, you could put a temporary blocking to support the side of the brace that is opposite the outside, to that the brace will remain square to the panels.koturban wrote:I'm assuming you are speaking of the parallel braces, and not the corner braces.
Re: THT LP build
Where should the braces go? Should they be lined up in a straight line or should they be staggered or does it matter? This is for the THT LP.
Thanks
Thanks
Re: THT LP build
"Staggered" with respect to....?
