Think again. If it's not in the plans there's a reason why, the most common one being that it won't work. And the fundamental frequency is moot. Good thing, as otherwise 99.9% of 5 string players would not be able to play a low B.iamlowsound wrote: I was thinking the 250 and extending the ports to make it a 30Hz tuning, as a low B is 31Hz.
First build Jack 112 x 2
Re: First build Jack 112 x 2
iamlowsound
Good thing I was going to check with you before I started building:) Would you recommend the T24 underneath if I wanted to hit the fundamental/give the low end a real boost?Bill Fitzmaurice wrote:Think again. If it's not in the plans there's a reason why, the most common one being that it won't work. And the fundamental frequency is moot. Good thing, as otherwise 99.9% of 5 string players would not be able to play a low B.iamlowsound wrote: I was thinking the 250 and extending the ports to make it a 30Hz tuning, as a low B is 31Hz.
lowsound
- Zack Brock
That will work fine and likely sound great... as long as you remain cognizant of the caveats of having sub bass on the stage, which will interfere with the front of house. Assuming the front of house is full range with subs then be prepared to make your FOH sound engineer very unhappy if you do! In cases where the FOH is lacking in the low end, you are good to go.iamlowsound wrote: Good thing I was going to check with you before I started building:) Would you recommend the T24 underneath if I wanted to hit the fundamental/give the low end a real boost?
lowsound
You could also consider a three way Omni 12 Full Range with two BP102's for the "subs" or a single 12". http://billfitzmaurice.net/Omni12.html
Personally, a pair of Jack 10's is all I've ever neded for backline and it sounds fantastic. I have four of them, Beta 10A loaded, and never had a need to use all of them at once. I play a 5" string and no complaints from me about low end authority out of a Jack.
Zack Brock
iamlowsound
Good to know, I am wanting to go with a rig that is as light weight as possible, so I'll probably just build the DR250, or maybe Jack 10L, and see if I am lacking anything in the low end department.Zack Brock wrote:That will work fine and likely sound great... as long as you remain cognizant of the caveats of having sub bass on the stage, which will interfere with the front of house. Assuming the front of house is full range with subs then be prepared to make your FOH sound engineer very unhappy if you do! In cases where the FOH is lacking in the low end, you are good to go.iamlowsound wrote: Good thing I was going to check with you before I started building:) Would you recommend the T24 underneath if I wanted to hit the fundamental/give the low end a real boost?
lowsound
lowsound
I recently had a discussion on that with a bass player on a DIY audio forum. Could not convince him that he did not need <40Hz for his 5 string. I should not have botheredBill Fitzmaurice wrote:Think again. If it's not in the plans there's a reason why, the most common one being that it won't work. And the fundamental frequency is moot. Good thing, as otherwise 99.9% of 5 string players would not be able to play a low B.
Hey Tim, congrats to you on your great looking and sounding cabs, nicely done
Sorry for the late reply but I've been on holiday for 2 weeks without much internet access. Glad I could help with the foam though. Maybe we can catch up again sometime compare notes on shuttle vs streamliner (no pun intended) or make a stack of 4 Jacks
cue stack of Jacks photos
Built: 2x Jack 112.
Bass: Cort Action A.
Amp: GenzBenz Streamliner 600.
Haha sounds good Jono! Team up with Harley and.... Boom!!
2 x Jack 112
2512, one with melded array
To do list:
XF 212
2 x Jack 112
To do list:
XF 212
- Charles Jenkinson
A futile exercise.AntonZ wrote: I recently had a discussion.......with a bass player on a DIY audio forum.
2xT30
2xT30
