DCX2496 remote??
Chris Betancourt
DCX2496 remote??
Hey guys has anyone used the remote software for DCX and what kind of connection did you use?
Christopher Betancourt
Authorized Builder
Puerto Rico
All running w/SAC or DL1606
On the table:
too much work!! LOL
Future:
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
- BrentEvans
Re: DCX2496 remote??
It requires a serial connection. You'll need a USB to serial adapter. Is not the best piece of software, but it works.
Chris Betancourt
Do you mean one of these??BrentEvans wrote:It requires a serial connection. You'll need a USB to serial adapter. Is not the best piece of software, but it works.
USB Port to 9-pin Serial RS-232 1 Meter Cable for PC & Mac, For Legacy Devices
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
gzc_stageTech
that's what I use, yes.
- BrentEvans
That looks right. Make sure it has drivers to support your operating system, and check what serial port it takes over. Most of the time com1 works best. You can change the port in the hardware config.
Chris Betancourt
Specifications:
Converts a standard 9-pin serial device to a USB port on your computer
Complies with USB Specification v1.1 & USB CDC v1.1
Compatible with USB Spec 2.0
Supports RS232 Serial Interface (standard 9-pin serial)
USB full speed communication and Bus Powered
Single Cable USB to Serial communications
Detects USB suspend condition
Supports Plug & Play specification
Supports Automatic handshake mode
Supports up to 1 Mbps data transfer rate
Support Remote wake-up and power management
Draws power directly from USB
Win 98SE, ME, 2000, XP, VISTA, WIN7 & Macintosh OS 8.6 thru 10.xx
Does NOT work with Mac OS X Leopard or newer
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
