The t24 or the Titan is really just a matter of what you shape prefer. I could see a Tuba 24 make sense in occasions where you get into the "sin" of pole mounting some sla's on top of the subs. Its not the best placement option, but an often requested setup for hire jobs. The titans are a bit top heavy, depending on driver, so its less practical.ajdroid wrote:Hi DJ - For its size quite it has quite a bit. I think most though are of the opinion that the T39 will get you more bang for your buck. Normally you'd choose Tuba's over Titans if you need the lows to go a bit lower. But if you're only building 2 T24's you're not going below 45Hz anyways which I think is what a T39 is crossed at.DJ Nada wrote:I'm in the process of building almost exactly the same thing. Does it have enough bass?
Best of luck to you!
AJ
SLA Pros and 24" T-24 Duallys
- Bas Gooiker
Re: SLA Pros and 24" T-24 Duallys
						- Chris_Allen
Assuming that the additional driver gives you an extra 3dB, this is what you get:
So that is:
8 cubic feet for the dual BP102 T24, 414cc
10.6 cubic feet for the 3012LF 24" T39, 494cc
8.8 cubic feet for the 3012LF 20" T39, 494cc
									So that is:
- Bas Gooiker
I wasn't trying to say that they are the same in output, but both will have "plenty of bass" for most smaller setups. I do know the Titans go louder, thats why i build them.
						- Chris_Allen
I was just trying to demonstrate that the T24 was perfectly capable and even though it less sensitive in some areas, it is a damn fine cab.  Not in response to any post, just data.
