Rope Caulk Walmart?
djlivex
Rope Caulk Walmart?
#1 Post by djlivex »
Does anyone here use the rope caulk from Walmart for sealing air tight spaces like metal handles and Neutrik metal plates to speaker cabinets? Obviously you can not use the foam weather strip because too thick. Thanks! :idea:
BaasssS, . . how low can you GO!
Michael Ewald Hansen
Re: Rope Caulk Walmart?
#2 Post by Michael Ewald Hansen »
djlivex wrote:Does anyone here use the rope caulk from Walmart for sealing air tight spaces like metal handles and Neutrik metal plates to speaker cabinets? Obviously you can not use the foam weather strip because too thick. Thanks! :idea:
If you buy Neutrik plates, handles etc from Leland he always provides gaskets for them, so you dont need to caulk it..
Authorized Builder - Denmark
#3 Post by Radian »
djlivex wrote:Obviously you can not use the foam weather strip because too thick.
I haven't used rope caulk in that application, but I can recommend using thinner (1/16") neoprene sponge foam gasket tape.
It squishes down to less than 1/32nd. McMaster Carr (#8694K62) and TCHweb (#556-NP11634900 ) both have the stuff. It's an alternative to using rope caulk if you already have the hardware in hand.
djlivex
#4 Post by djlivex »
I already have the rope caulk but will look at the thin gasket, thanks! :)
