Titan 48 (OSB panel), Beyma Power15, GDN-38-550-8-AE
jzagaja
#1 Post by jzagaja »
This is my Titan 48:
http://youtu.be/u73lNro99cY
driven with Beyma Power 15 and GDN-38-550-8-AE (Qt=0.9). Do you see air leaks on impedance plot?
Re: Titan 48 (OSB panel), Beyma Power15, GDN-38-550-8-AE
#2 Post by Bill Fitzmaurice »
No obvious air leaks, but a few resonances, probably from using OSB, which is not suitable for speaker cabinets.
jzagaja
#3 Post by jzagaja »
True - I wanted to have something light and quick on New Years Eve. 40Hz dip is too strong compared to your samples?
#4 Post by Bill Fitzmaurice »
jzagaja wrote:True - I wanted to have something light and quick on New Years Eve. 40Hz dip is too strong compared to your samples?
Not necessarily. I didn't test mine with that driver.
jzagaja
#5 Post by jzagaja »
Simulation. Impedance of real speakers is shifted toward lower frequencies.
netwerks
#6 Post by netwerks »
OSB...light???? :noob:
jzagaja
#7 Post by jzagaja »
Ok. maybe not light but certainly a lot cheaper to experiment :D - I wanted to see how my drivers behave.
Rick Lee
#8 Post by Rick Lee »
netwerks wrote:OSB...light???? :noob:
Actually, only 2 lbs. heavier than regular plywood.
Authorized Builder
Nashville/Middle Tennessee
bwtaudio@gmail.com
Lastcat
#9 Post by Lastcat »
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
jzagaja
#10 Post by jzagaja »
I sealed internal walls and covered OSB with felt. Impedance has changed as you can see because I removed 6mH coil.
What 6mH coil? :confused:
jzagaja
#12 Post by jzagaja »
I disassembled my Beyma Power 15 from aperiodic enclosure (5 cu. ft), put in Titan48 and forgot remove low pass filter. In comparison to closed box bass is more felt on body but this is ca. 70Hz not 40-50Hz :) We'll see on Monday. It vibrates quite a lot ;)
jzagaja
#13 Post by jzagaja »
It cost me no more than $50 plus woofer.
