Bought a S/H Allen & Heath powered mixer ( see this - http://billfitzmaurice.info/forum/viewt ... 28&t=18780 ) off ebay which turns out to have a lot of problems. The seller has said that he'll refund me at the end of the month although I'm not holding my breath!
Anyway, since I have a couple of weeks to wait I may as well try to find some time to see if I can repair it. Does anyone know where I can get a schematic / service manual?
It's a PA12-CP 1000W mixer.
Many thanks
Request for help with mixer repair
Re: Request for help with mixer repair
Tell us what the problems are!
Google is my friend.
http://www.allen-heath.com/UK/Products/ ... bset-tab-4
Page 33 of the user manual gives a block diagram. Or the block diagram is a seperate download.
This may be a service manual:
http://fileshare.eshop.bg/downloadsm/57 ... eries.html
Hope that helps...
Hope that helps...
Wow, thanks! How did I miss that?
That's the mixer alright, looks like a full schematic in the service manual from first glance.
The mixer has many faults although sometimes these can be traced to a few. I'll really need to get a proper diagnosis.
NTB
8o)
NTB
8o)
keep us posted on how the troublehooting goes
you never know if another member will have something similar
and your findings can help the community
It is not the bananas but the monkey
Will do. Need to gather some equipment. Have a working 'scope and will grab a PSU from the bay. Should be enough to get going.
NTB
NTB
ntblade wrote:Will do. Need to gather some equipment. Have a working 'scope and will grab a PSU from the bay. Should be enough to get going.
Good grief man! Did you buy a boat anchor??
Boat anchor! Almost.
http://tinyurl.com/bsp23cc
I'm trying to get a refund. Apart from not working, the carry handle is missing (not shown in photo) and the rack ears I was told were with it aren't.
I'm not holding out much hope of getting my money back so this might be a project for the winter.
The PSU I'm referring to is a bench type to power the mixer when being repaired as I'll have to remove the channel modules to check them individually.
NTB
NTB
