T39 Slim x2
djtrumptight
Re: T39 Slim x2
I copied the picture of your cab and blew it up,it looks like there are area's where you dont have squeeze out on some area's of your braces unless you cleaned up the squeeze out.If not it would be best to make sure you seal those braces before you seal it up or your cab may rattle.Looks good though.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
Re: T39 Slim x2
djtrumptight wrote:I copied the picture of your cab and blew it up,it looks like there are area's where you dont have squeeze out on some area's of your braces unless you cleaned up the squeeze out.If not it would be best to make sure you seal those braces before you seal it up or your cab may rattle.Looks good though.
Yeah, I scraped off the excess on the lower 5-8 brace because it will be visible through the horn mouth. Probably wouldn't be an issue really, but I wanted to be sure the paint would stick.
Plus, even if nobody ever saw it, I'd still know, and that wouldn't sit well with my inner perfectionist.
Andy
djtrumptight
Re: T39 Slim x2
Perfection around here is "well braced and airtight".Alien wrote:djtrumptight wrote:I copied the picture of your cab and blew it up,it looks like there are area's where you dont have squeeze out on some area's of your braces unless you cleaned up the squeeze out.If not it would be best to make sure you seal those braces before you seal it up or your cab may rattle.Looks good though.
Plus, even if nobody ever saw it, I'd still know, and that wouldn't sit well with my inner perfectionist.![]()
Andy
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
Re: T39 Slim x2
I hear you dude, let me assure you those braces are going nowhere.djtrumptight wrote: Perfection around here is "well braced and airtight".
Anyhow, here's how things lie currently Hi-tech clamping apparatus in use
Finally got 'em closed up.
All rounded over, sanded and ready to go.
Managed to get the inside of one of the horn mouths painted before the rain started
Andy
Re: T39 Slim x2
Very nice work.....
Why do we keep covering up that beautiful wood with Duratex?
Yeah, yeah....I know.
djtrumptight
Re: T39 Slim x2
Sweet.....
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
Re: T39 Slim x2
Noice!
Re: T39 Slim x2
Thanks for the props guys - got a couple of coats of tuffcab over most of the pair today, so should be finished soon
Hopefully, they'll be ready in time for their debut at a gig I'm doing next Sunday - live band and disco for a christening do. I'll post a review thread then.
A
A
biggerrigger
Re: T39 Slim x2
Nice clean build. Good looking slims.
4-25" Lab12 loaded T39's
2-DR250's Melded array
2-DR250's Flat array
Re: T39 Slim x2
Wahey, they're finished!!!
Driver in, just prior to leak testing
Closeup of one of the drivers. They're Eminence OEM's branded as American Sound. They spec out pretty similar to the BP102-4, but with a bit lower power handling.
All closed up and ready to run. Running one of them outside at 10V/50Hz made the shed vibrate, something my old Peaveys never managed. Can't wait to get them running at war volume
Tomorrow I'll set up the limiters etc on my brand spanking new DCX2496 and give them a little thrash while the house is empty
Andy
Andy
Re: T39 Slim x2
Very nice! I had some OEM rebranded Eminences for subs (pre BFM days) and they worked well. Big xmax 18"'ers. Don't knock the shed down!
- Bas Gooiker
Re: T39 Slim x2
Looking good... now rock the house!!!
