Omni 15 Tallboy - my first build
Re: Omni 15 Tallboy - my first build
#61 Post by AntonZ »
Something similar goes for Duratex. Try on some scrap wood first. If it does not hold well, you can apply some black/darkgrey latex paint first (as a primer coat). Warnex will probably stick to that. Again, try on scraps first.
#62 Post by Bruce Weldy »
Prime it first, then it should stick.
Bas Gooiker
#63 Post by Bas Gooiker »
I used automotive 1/50 filler over screws and holes. Then some spray on automotive primer... works like a charm, Warnex will stick to that no problem.
If you gonna paint it white, make the horn mouths black for a nice contrast...
#64 Post by Tom Smit »
Rickyvt wrote: The problem here is that I have some sunken screws hidden with filler. You remind me of my wife, she said just the same about staining it to match the bass :D
But I don't know if I'm gonna keep this bass as long as the Omni TB...
I, too, was thinking that a stain would look really good. That picture really shows it off nice.
Rickyvt wrote:The Tuff Cab technical data says not to paint over anything containing cellulose solvents like filler, primers... I've used the two component type filler with hardener 1:50. It doesn't state anywhere that it contains solvents. Would it be safe to use Tuff Cab then?
If you pre-paint the cab with a cheap paint, you should be able to use the Tuff Cab....similar idea when using Duratex on PL. :fingers:
Do you feel royal? Go with purple.
Rickyvt
#65 Post by Rickyvt »
Thanks to all for the extra info on painting!
After rounding the corners and deciding on the color, I will definitely show the results!
Wheels and handle.
Wheels and handle.
OmniTB2 (1).jpg (21.4 KiB) Viewed 3565 times
Rickyvt
#66 Post by Rickyvt »
Bas Gooiker wrote:I used automotive 1/50 filler over screws and holes. Then some spray on automotive primer... works like a charm, Warnex will stick to that no problem.
I was thinking about the same, and a glow in the dark UV phase plug :wink:
I think a stained look doesn't really match the design of the wheels so it will probably be a paint job...
Rickyvt
#67 Post by Rickyvt »
Found out that the mid driver wasn't hitting the phase plug, it was a combination of pedal/amp settings :slap:
Damn it sounds great. I think I'm going to make me some Jacks too...
Rickyvt
#68 Post by Rickyvt »
I rounded the edges, so some more photos...
Backside wheel
Backside wheel
Not rounded
Not rounded
Rounded
Rounded
Harley
#69 Post by Harley »
Interesting wheels there Rickvyt.
Do you have a close up shot of them please? Or a link?
Bas Gooiker
#70 Post by Bas Gooiker »
Harley wrote:Interesting wheels there Rickvyt.
The weels in the picture are:
http://www.thomann.de/nl/adam_hall_3745 ... krolle.htm
Rickyvt
#71 Post by Rickyvt »
Indeed they're the ones I put on it. I made slight changes to the back panel and flanges to make it fit. Luckily the woofer just passes through :hyper:
And here is your close up:
bassmonster
#72 Post by bassmonster »
Interesting wheels. They look like rollerblade wheels, I wonder if they wouldn't rattle as much as regular casters at high volume?
biggerrigger
#73 Post by biggerrigger »
I was just thinking the same thing about the rattles. I have resorted to placing a piece of folded Coors Light beer box into the wheels every time I gig to keep the wheels from rattling. Yes that's right folks T39's at full tilt require you to drink a 12 pack of bottles to keep the wheels quiet. So drink up and Jam :mrgreen:
4-25" Lab12 loaded T39's
2-DR250's Melded array
2-DR250's Flat array
bassmonster
#74 Post by bassmonster »
Yep, I fold up pieces of paper for the same reason. 8)
Rickyvt
#75 Post by Rickyvt »
They are indeed kinda soft like roller blade wheels. For now no rattle at all. Haven't tested it at a real live gig but I can go pretty loud at my studio without disturbing the neighbours.
