THT Build
Chompy191
THT Build
#1 Post by Chompy191 »
Starting my Tuba HT Build, I'm building this at school as a project
(access to panel saw etc) :) .
Details...
- Re SRX15D2
- Dayton SA-240B plate amp
- 24.5" wide
- 5 ply plywood (decent grade)
- Selleys Liquid nails Platinum
progress is good so far, up to installing panel 1.
Cut out the driver access using a jigsaw, starting each
cut by drilling a few small holes and making a gap for
the saw to start off with a flat head screwdriver, seemed
to work ok.
TTLS 17"
THT 24.5"
2x THT 16"
SLA LCR
Otop12 x2
Titan 48 24"
Chompy191
Re: THT Build
#2 Post by Chompy191 »
anyone else find the braces need to be slightly smaller than specified in the plans?
TTLS 17"
THT 24.5"
2x THT 16"
SLA LCR
Otop12 x2
Titan 48 24"
Re: THT Build
#3 Post by Radian »
Chompy191 wrote:anyone else find the braces need to be slightly smaller than specified in the plans?
Depends on the wood.
Best method is to use the layout lines to mark on the side panel the starting points for the reflectors, but then use a piece of scrap ply to trace the actual outline of the piece.
Measure that outline, and parts cut from those dimensions will be a precise fit. That's what Bill means in the plans by Dead Reckoning.
Chompy191
Re: THT Build
#4 Post by Chompy191 »
build is coming along nicely :hyper:
That 1/2 inch notch in front of the driver
doesn't look all that much now its installed
but hopefully no worries.
TTLS 17"
THT 24.5"
2x THT 16"
SLA LCR
Otop12 x2
Titan 48 24"
shawn_g
Re: THT Build
#5 Post by shawn_g »
Looking good. You're on the home stretch now. 8)
Chompy191
Re: THT Build
#6 Post by Chompy191 »
Finally some more progress after waiting a week for more plywood.
I'm thinking a black finish will be the way to go but not really sure
what would look best, roller, spray paint etc. Any ideas?
TTLS 17"
THT 24.5"
2x THT 16"
SLA LCR
Otop12 x2
Titan 48 24"
Re: THT Build
#7 Post by Grant Bunter »
Great to see another (younger) Aussie doing a build!
Looking great so far!
All the best for your project :)
ps, you'll get a bit excited about your end result. Of the cab that is...
Chompy191
Re: THT Build
#8 Post by Chompy191 »
:D :D
TTLS 17"
THT 24.5"
2x THT 16"
SLA LCR
Otop12 x2
Titan 48 24"
Chompy191
Re: THT Build
#9 Post by Chompy191 »
hopefully putting the side on tomorrow :D
TTLS 17"
THT 24.5"
2x THT 16"
SLA LCR
Otop12 x2
Titan 48 24"
bassmonster
Re: THT Build
#10 Post by bassmonster »
Cool build!
The next 48 hours will be the worst wait of your life. After putting on the final side, you must fight the temptation to fire it up for an entire day until the PL cures. Be strong. :mrgreen:
Chompy191
Re: THT Build
#11 Post by Chompy191 »
Got the side panel installed today, only just had enough liquid nails left to cover all the edges. Lined up reasonably well, all my pre drilled holes were in the correct locations. Some of the outer panels were warped but got them flush using a bar clamp then screws.
TTLS 17"
THT 24.5"
2x THT 16"
SLA LCR
Otop12 x2
Titan 48 24"
Dan30
Re: THT Build
#12 Post by Dan30 »
Looks awesome Chompy. I hope you enjoy it.
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
Bas Gooiker
Re: THT Build
#13 Post by Bas Gooiker »
Looking great there.
I'll use this picture as leverage for permission to put the titans in the living room. Theyre hardly bigger than the "average" HT sub. :twisted:
Re: THT Build
#14 Post by Grant Bunter »
Chompy,
Liquid nails is great stuff. I'm not sure the platinum version is expanding polyurethane.
It's absolutely vital for these cabs they are leak free. Absolutely positively in the driver chamber.
If your selleys hasn't oozed out and left an nice squeeze out, it will be very difficult to address now that final side is on!
:fingers: for you...
If you decide to do another project, PL is available in Australia.
Chompy191
Re: THT Build
#15 Post by Chompy191 »
yeah I'm pretty confident there are no leaks.
I used a generous amount on all joints and I didn't get any leaks
when I built my TTLS. From what I can tell it seems to expand a fair
bit when it dries.
TTLS 17"
THT 24.5"
2x THT 16"
SLA LCR
Otop12 x2
Titan 48 24"
