Omni 15 Tallboy - my first build
Re: Omni 15 Tallboy - my first build
Thanks ketoet! I'm just taking advantage of any free time I got. Very happy with it so far...
Still very cool
That's a nice clean build Rickyvt, great job.
Built: 2x Jack 112.
Bass: Cort Action A.
Amp: GenzBenz Streamliner 600.
Thanks Jonoskip!
I see you have two Jacks 112. How do you like those? Do you use both of them all the time? I have the plans for the Jack 112, so I'm considering making those too...
I'm also playing a Cort bass (5-string), by the way
I hesitated a while about breaking in drivers, but after reading Bill's post about it, I'm finally breaking in my woofer. I guess the tweeter doesn't need this. Should I break in the Mid Range driver too? If so, should I use 30kHz/10V or is that different for mid range drivers
Added a speakon/L-pad panel at the back. Will be adding the top panel probably today...
SirNickity
NO.Rickyvt wrote:Should I break in the Mid Range driver too? If so, should I use 30kHz/10V or is that different for mid range drivers
I like my Jacks but I don't have much experience to compare with other cabs. Sadly I am yet to really crank them up as I'm only playing in my garage at the moment and I don't want to piss the neighbours off! So I usually just use 1 but that is the beauty of building them separately.Rickyvt wrote:Thanks Jonoskip!
I'm also playing a Cort bass (5-string), by the way.
I like my Cort but am starting to think about what else there may be out there. No real desire to change yet, just keeping an open mind.
Built: 2x Jack 112.
I skipped breaking in the midrange driver 30kHz is OK, but 550kHz is driving me nuts.
Today I did the low pass and mid range band pass, could not resist to play some bass at low level
The crossovers seem to be OK...
Still need to do the braces and insulation, high pass filter and access panel.
Unless you are a dog, you shouldn't have any problem with 30khz.....but it's also not going to do a very good job of breaking in your driver.Rickyvt wrote:I skipped breaking in the midrange driver 30kHz is OK, but 550kHz is driving me nuts.
Yesterday I showed it to the guitarplayers of our band and even the most suspicious one was impressed. The other one wants to team up with me to build an XF Guitar cab...
Gregory East
Tell him you'll help out on the XF if he goes to a 15W amp.
He's the guy who is very modest with his volume settingsGregory East wrote:Tell him you'll help out on the XF if he goes to a 15W amp.
- Michael Ewald Hansen
You should have one of the coils standing up to avoid cross-talkRickyvt wrote:I skipped breaking in the midrange driver 30kHz is OK, but 550kHz is driving me nuts.![]()
Today I did the low pass and mid range band pass, could not resist to play some bass at low levelThe crossovers seem to be OK...
If you're interested in knowing why:
http://www.audioholics.com/education/lo ... alk-basics
Authorized Builder - Denmark
Thanks for the info, nice to know someone with knowledge and experience is looking over my shoulderMichael Ewald Hansen wrote:
Crosstalk can be a problem when the LP/BP/HP filters are on the same board. When mounted on separate boards the coils are too far apart for it to be a concern.Michael Ewald Hansen wrote: You should have one of the coils standing up to avoid cross-talk![]()
