Omni 15 Tallboy - my first build
Re: Omni 15 Tallboy - my first build
looks excellent so far. it really is addictive to build bill's cabs. it's been 2 years since i started my first biuld and i haven't stopped since.
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
I should have bought the CD...
I cut the mid horn panels today, just need to do the baffle holes...
By the way, doesn't the tweeter need a grill? The APT 80 has a sharp cone in the middle and I wouldn't want anybody to hurt their fingers
- bitSmasher
people that stick their fingers in a speaker deserve to get stabbed
I wasn't worried about them, to be honest
but leaving it without a grill doesn't seem like a good idea. The plans don't mention anything like a grill...
Maybe you should use a piece of scrap wood when fastening, before piercing that kind of holes. You will avoid marks.
Anyone sticking their fingers into my cab would end up losing them.Rickyvt wrote:I wouldn't want anybody to hurt their fingers
I only needed the plug, the rest of the plywood is scrap, so any marks don't matterrainbass wrote:Maybe you should use a piece of scrap wood when fastening, before piercing that kind of holes. You will avoid marks.
if want you can use a grill. the plans don't mention one but it's been done before. mine have grils to because i rent them out and it avoids crap getting into the horn
greetz ketoet
greetz ketoet
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
It might be an unnecessary cost but I would like to be sure. I'll google for them!
Meanwhile I'm ready to put the Midrange Horn together. I'll post some pics later on...
The mid horn took a while...
The phase plug in the baffle panel is slightly larger (about 1/16") than the one glued on it, which has the correct size. Should I correct that or is there nothing to worry about?
Dry fitting. It's a very, very tight fit. Don't think I need glue
I will have to do some sanding before glueing it
very nice looking cab. keep up te good work.
wish i could make so much progress each day
greetz ketoet
greetz ketoet
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
