The system
netwerks
Re: The system
#16 Post by netwerks »
SONIDO TUMBAO wrote:
Bill Fitzmaurice wrote:
SONIDO TUMBAO wrote:SYSTEM... :hyper:
Your top placement is a textbook example of how tops should not be placed. And this is the book:
http://www.gtaust.com/filter/05/07.shtml
Although he was badly off the Titans and lod HD215 and the media .... was heard a low awesome.
Para spanish a english traducir, contacto usuario SesTres para helpo. :)
SONIDO TUMBAO
Re: The system
#17 Post by SONIDO TUMBAO »
I feel it lacks power as compared to other titans lower than I had, for example the B-09 Beyma manual. I can do to get lower in my cabinets .... will need to do more?
6 Titanes 48
8 DR250 en process con CD
SONIDO TUMBAO
Re: The system
#18 Post by SONIDO TUMBAO »
Hello Mr. Bill, I want to buy the planes of OTOP 12 J Array and deposit in Mexico where I say that having your address:
106 Baldwin ST. Laconia NH 03246,
It is not sufficient and require the state where the data will make the deposit.
I hope your information and I'm interested in those planes. :cowboy:
6 Titanes 48
Re: The system
#19 Post by Tom Smit »
SONIDO TUMBAO wrote: 106 Baldwin ST. Laconia NH 03246,
NH means New Hampshire.
SONIDO TUMBAO
Re: The system
#20 Post by SONIDO TUMBAO »
Thanks :hyper:
6 Titanes 48
Chris Betancourt
Re: The system
#21 Post by Chris Betancourt »
Puedes postear lo en espaNol q te ayudo a traducir. Cual es tu prugunta para ayudarte?
Christopher Betancourt
Authorized Builder
Puerto Rico
All running w/SAC or DL1606
On the table:
too much work!! LOL
Future:
SONIDO TUMBAO
Re: The system
#22 Post by SONIDO TUMBAO »
Chris Betancourt wrote:Puedes postear lo en espaNol q te ayudo a traducir. Cual es tu prugunta para ayudarte?
Gracias la pregunta era que cual era el estado para enviar el dinero, ya que aqui en méxico me piden el estado, saludos, me gustaria ver tu sistema de 12 dr250, que tal suena, y que cantidad de gente cubre. :cowboy:
6 Titanes 48
spongebob1981
Re: The system
#23 Post by spongebob1981 »
NH significa New Hampshire.
"Yep, deep orange" 2xJ10
(other site) 50W DIY Tube Head
"La música es el delirio. Bienvenidos al delirio."
Chris Betancourt
Re: The system
#24 Post by Chris Betancourt »
spongebob1981 wrote:NH significa New Hampshire.
Esto es correcto, pero Bill te envio la direccion postal? Tu tienes paypal?
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
Re: The system
#25 Post by Tom Smit »
(I used Google Translator)
Usted puede abrir una cuenta en Paypal para ti. Todo lo que necesitas es una tarjeta de crédito o cuenta bancaria que PayPal puede obtener el dinero de.
SeisTres
Re: The system
#26 Post by SeisTres »
LOL, this made me laugh :lol:
Man! these internet translators still have long ways :( And i'm feeling lazy so, no, I will not be writing things twice in both languages.
Bueno, aqui voy.
La forma en cual estas usando tu systema es el tipico ejemplo en como NO se debe usar. Las frequencias de los bajos (graves) si son omnidireccionales y por eso normalmente son juntados en una sola pila de bocinas. Y aun asi, tambien tienen un cierto limite a cunatos puedes juntar antes de que las frequncias se vuelvan direccionales. Pero con solamente ocho no necesitas preocuparte de esto. Pero el problema mayor es que las frequncias de las "tops" son affectas gravemente con esta configuracion.
Las frequencias altas (agudas) so muy chiquas y cuando usas tu systema de este modo causas el effecto llamado "comb filtering". Esto resulta que la covertura sea muy irregular pues unas frequencias desapareceran y otras seran magnificadas. El otro effecto negativo es causado por esta configuracion es que con tantas bocinas en linea las frequencias se vuelven direccionales y en realidad estas disminuyendo la dispersion.
Y con tanto typos de diferente bocinas, es casi impossible equalizar ya que cada una suena diferente.
Como un systemo de estos debe ser usado es como normalmente es visto en unas de las fotos aqui. Los bajos todos juntos pero las tops en pilas verticales, no lineas horizontales. Esta configuracion te da la maxima covertura de dispersion horizontal y al mismo tiempo reduciendo la dispersion vertical cual es beneficial lla que no se necesita y simplemete seria energia gastada. Esta es la razon que los esta tops son disen~adas para poder ser usadas en pilas verticales.
Pienso que este es problema que estabas teniendo con tu dr250. Este disen~o tiene dispersion muy grande a lo horizontal per muy reducida a lo vertical. La bocina debe estar al nivel del publico. Esta es la razon que no es un cubo pero tiene los angulos para poder acer un "j array".
Ya que si necesitas sonido para un lugar muy amplio lo mejor es usar mutiple pilas verticales de "tops". Deben tener una separacion de por lo menos 5 metros. Si tambien necesitas separar los bajos para cubrir lugares muy grandes, separalos por lo menos 16 metros.
SONIDO TUMBAO
Re: The system
#27 Post by SONIDO TUMBAO »
Mas fotos del Sistema 6-t48***4-HD215***2-TSE-111
:hyper:
6 Titanes 48
Rich4349
Re: The system
#28 Post by Rich4349 »
Parece que todo el mundo tenía un buen tiempo.
Algunos consejos sobre los subwoofers : A pesar de que su rostro es agradable a la vista , que está perdiendo un montón de bajo teniendo las caras tan lejos de la pared . Ciertas frecuencias de graves van a la pared del fondo , así como a la audiencia , y luego rebotando de espaldas al público , causando cancelaciones . El subwoofer utiliza una gran cantidad de su fuerza para luchar contra sí misma, con un resultado de menos graves . Coloque la cara del subwoofer de 8 a 12 centímetros de la pared . ( Mejor aún , una esquina . ) Las frecuencias bajas será más suave , Y más fuerte. Es mucho más fuerte , que es como tener seis subwoofers más ! ( Es como NUEVE más en la esquina! )
SONIDO TUMBAO
Re: The system
#29 Post by SONIDO TUMBAO »
Entiendo lo de los T48 en la esquina como los marca el Sr. Bill en su manual de construcción, el problema es que aca en Mexico uno coloca el equipo donde la gente del salon o la fiesta te dice, así que es muy dificil hacer eso, ya que es el lugar que asignan para el equipo.... :wall:
Por otro lado quiero hacer un sistema clon de dv-Dosc pero con 2 bocinas de 10" en lugar de 8", pero me llama la atención el J12 , tu lo haz oido en vivo.
Quisiera que alguien que tiene el J12 me diga con que otro equipo lineal lo ha comparado, quizas ya con J12 no ocupe mas los HD215, y haga mas T48, tengo 22 bocinas de 15" :cowboy:
Rich4349 wrote:Parece que todo el mundo tenía un buen tiempo.
6 Titanes 48
escapemcp
Re: The system
#30 Post by escapemcp »
¿qué? :mrgreen:
