DR250 Build
Tedward
Re: DR250 Build
#16 Post by Tedward »
Apologies accepted. All is cool. :D
For my own peace of mind I ordered my own set of plans. I see what you mean about the older version of the DR 250.
And so, the build goes on. I got a few jobs. I'm a painting contractor and have three houses to paint. So, the DR build is going to slow down a bit but, I'll keep posting the build as I go.
Tedward
Re: DR250 Build
#17 Post by AntonZ »
Tedward wrote:And so, the build goes on. (snip) , I'll keep posting the build as I go.
Hurray! :clap:
Tedward
Re: DR250 Build
#18 Post by Tedward »
Here's what I have so far.
In the second photo do you see the mistake I made. That's what happens when I take break for a few days and don't take of notes as to where I am in the build
What do you guys use to tidy up the front of the tweeter array. I used wax paper on the jig to keep any glue seepage from sticking.
Re: DR250 Build
#19 Post by Bruce Weldy »
Excellent workmanship :clap:
kekani
Re: DR250 Build
#20 Post by kekani »
First off,I'm sure I'm one of the more than handful that appreciate you sharing your excellent builds.
Tweeter array: I use abs between the tweets to set it up, then glop it on the backside. I believe the DR needs to be sealed, so this should work well there. On the front side, I take a cabinet scraper and lightly go to town. Yes, it'll take off the textured surface, but if it's even, no one will notice. Or just hit a quick flat black spray paint, then it'll be good, from far.
Aaron
Wedgehorn 6 (x2)
Jack 110 Lites (x2)
XF212 (Egnater style)
DR200 ASD (Yes! Finally!)
Tedward
Re: DR250 Build
#21 Post by Tedward »
Thanks Bruce.
Aaron, I used abs cement on this array and it is a lot stronger that the arrays for my J12L's. Model airplane glue just won't cut it as far as strength. A scrapper is what I used on the J12L's and they came out looking pretty good. I just thought that there was something else I could do.
As far as leaks I have checked with a bright light behind them three times and keep finding pin holes, I'll keep doing it until I don't find any.
Tedward
Tedward
Re: DR250 Build
#22 Post by Tedward »
Saturday night and time to relax and watch a movie (Predator) our soon to be daughter in law hasn't seen it yet.
Here's where I am now.
If you haven't guessed what my mistake was; I forgot to pre drill the holes for the bolts to mount the driver. Oh well I'll figure something out.
I measured the array and it is 20 1/4" long, a little short. I'll have to add some wood to the tweeter braces at the top and bottom.
Do any of you end up with your angles off? I think I'll get an accurate protractor.
That's it for the weekend. Happy fathers day to all you dads.
Tedward
Tedward
Re: DR250 Build
#23 Post by Tedward »
It's been a while and the DR's are completed. They sound phenomenal and are LOUD!!!!
Thanks for the design Bill.
Re: DR250 Build
#24 Post by Grant Bunter »
That's a great build Tedward :)
Re: DR250 Build
#25 Post by Tom Smit »
Nice build! And good recovery with getting the driver located right...after the fact of not predrilling!
Are you going to post in the "Review" section? huh, huh, huh?
Re: DR250 Build
#26 Post by LelandCrooks »
Nicely done.
on1sony
Re: DR250 Build
#27 Post by on1sony »
Have any pictures of the finished product? How are the loudspeakers doing?
6xBFM TUBA60 30" WIDE
4xBFM DR280's
4xQSC PL325 AMPS
DBX PA+
2xQSC K12 Monitors
AutoTuba 10" Driver (Building Soon)
Re: DR250 Build
#28 Post by DJPhatman »
Andre I know you are excited about your build being close to done, but this thread is just shy of a year old. :roll:
miked
Re: DR250 Build
#29 Post by miked »
Wow, that's some great craftsmanship! Would love to see pics of the finished product and your thoughts on the sound.
Altec Best
Re: DR250 Build
#30 Post by Altec Best »
Nice woodworking Skillz !
Mankind's Great Problem Is A Perfection Of Means But A Confusion Of Ends ~ Einstein
