DR200s and Slim T60s
DJ Higgumz
#1 Post by DJ Higgumz »
Bought the plans today for DR200s and T60, and I plan on the following orientations-
DR200 - 2 with beta 8 and full flat array. i would do the melded, but from what i understand in smaller rooms the wide dispersion causes a lot of reverberation. would it be better value to go with the 18 sound driver? how many tweeters would i need to keep up with it?
T60 - 4 20" lab 12 loaded, only loading 2 for now, then adding the next two as money allows.
I may build custom lighting case with lights and tripods all in it, and also an all in one rack housing my large mixer, 19'' rack equip, tower computer, and midi controller. it all depends on :broke:. i would love to just plug in power and speakers and be ready to go!
i hope to build after the 2nd of june, got a high paying lock-in hopefully in place. :fingers:
what are your thoughts on these configurations?
Building
4 30" T60s
2 19" T60s
1 30" T39
3 Autotubas with GTO804
Bought
2 Dr250s
J_Dunavin
Re: DR200s and Slim T60s
#2 Post by J_Dunavin »
I would think that you would need four DR200's
DJ Higgumz
#3 Post by DJ Higgumz »
would I? i've been doing gigs with no more than 300 ppl. how is the 18 sound upgrade compared to two cabs, beta loaded. i know there will be smoothed response, but besides that, what would be the advantage?
Building
4 30" T60s
2 19" T60s
1 30" T39
Bought
2 Dr250s
djtrumptight
#4 Post by djtrumptight »
The advantage would probably be in being able to give the cab more voltage and getting more output from the cabs.Thats a weird combo,DR200's and T60's,there is no way 2 DR200's are gonna keep up with 4 T60's,especially using Beta drivers.Word of advice,use a recommended driver but i take it u know what u need.When i built my cabs i kept in mind that i would use these for the rest of my life so why skimp ? Spend the money if u can,its well worth it.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
BassMe
#5 Post by BassMe »
Use the Delta Pro 8 it's like $30 more each cab. And it is according to Bill FAR more suitable for the Dr200 than the Beta 8. Also how close are your audiences? Because the melded array (even though it hits the walls more) will be a better choice if people are within 30 ft of the tops. You can fix reflection with EQ, you can't fix dispersion. Also everyone is going to be moving around anyway. You want a sweeter area not a sweet spot.
#6 Post by LelandCrooks »
With beta 8's you will need 4. With the delta pro's 2 might keep up, higher max spl because of power handling. And yes for 300 a pair should be enough. But 4 t60's is complete overkill for 300, so we're recommending more DR's for that reason.
DJ Higgumz
#7 Post by DJ Higgumz »
I don't think it would cost me much more to build the boxes, so I'll build 4 and load 2 like with the t60s. Then I would do 2 melded and 2 flat.
Building
4 30" T60s
2 19" T60s
1 30" T39
Bought
2 Dr250s
DJ Higgumz
#8 Post by DJ Higgumz »
at speakerhardware, there's the two choices of casters, 2 1/2 inch and 3 inch. i personally like the black look of the smaller and also the price. would there be any problems with them on a t60? i hope for some quick replies, i'm ordering the t60 stuff right now :hyper:
Building
4 30" T60s
2 19" T60s
1 30" T39
Bought
2 Dr250s
bassmonster
#9 Post by bassmonster »
I used the 2.5" casters on my dual TT. They buzz a lot at high volume. At really high volume the rattle is drowned out however. If there are some casters that have special bushings that don't rattle, get them instead.
DJ Higgumz
#10 Post by DJ Higgumz »
If they are also used as cabinet feet, will they still rattle?
Building
4 30" T60s
2 19" T60s
1 30" T39
Bought
2 Dr250s
djtrumptight
#11 Post by djtrumptight »
bassmonster wrote:I used the 2.5" casters on my dual TT. They buzz a lot at high volume. At really high volume the rattle is drowned out however. If there are some casters that have special bushings that don't rattle, get them instead.
Did u use swivel casters ?
2 SLA HT systems
2 SLA Pro's
bassmonster
#12 Post by bassmonster »
Yes, I used two swiveling casters and two straight casters.
#13 Post by LelandCrooks »
You really want the 3" for t60's.
DJ Higgumz
#14 Post by DJ Higgumz »
Alright thanks! Before I can order i need to deposits money into paypal
Building
4 30" T60s
2 19" T60s
1 30" T39
Bought
2 Dr250s
djtrumptight
#15 Post by djtrumptight »
I have swivel casters on my T 48's and when i crank them those casters spin like roller skates.i just put a piece of duct tape on them to stop the spinning.
2 SLA HT systems
2 SLA Pro's
