It's about time to think about painting the 4 T39s. I'm eventually putting on grills with 3mm acusitic foam backing, which is why I didn't chisel out any squeezeout, but I want to Duratex the mouth area anyway. The Duratex should be on it's way form Leland soon.
I know that Suratex won't stick to PL, so I thought to hit the squeezeout with something that it will stick to.
My 2 candidates are:
1) decent flat black latex house paint from the Borg
2) rattlecan of flat black Krylon
Option one is nice b/c I can hit the whole box with it before Duratexing.
Primer
Re: Primer
Option 1
Paint the whole thing in flat black. You'll use less duratex to cover that way. Let the wood soak up the cheap paint and save the expensive stuff for the top coat.
Re: Primer
I order my duratex from Leland on Monday. All my cabs except the newest have a couple coats of flat back on them.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
- Scott Brochu
Re: Primer
I sometimes use 2x coverage spray paint or roll on some interior/exterior paint. Than do a nice sprayed Duratex to finish.
But the Duratex bond is only as good as the primer coat you put on first. Just some side notes.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
el_ingeniero
Re: Primer
I went to the Home Depot and looked at primer. They didn't have any in flat black, and they claimed that they couldn't tint primer to black. So I guess I am looking for paint not primer. So the next question is:
Oil or Latex?
Oil or Latex?
Re: Primer
From what I've read on here before that would be latex. I've had flat black latex on mine for over one year...just now getting to duratexel_ingeniero wrote:I went to the Home Depot and looked at primer. They didn't have any in flat black, and they claimed that they couldn't tint primer to black. So I guess I am looking for paint not primer. So the next question is:
Oil or Latex?
Donny Collins
el_ingeniero
Re: Primer
So I went back to the Borg today, and found a gallon of Behr Premium Plus Flat in the "Oops" shelf, that was so close to black you might as well call it black. $7.
It's not the best, but it will do for the mouth.
Re: Primer
Get a good latex primer, then ask the guy/gal at the paint counter to pour some off until there is 1" of headroom and do a custom color with enough black to fill it back up to the top. That will be a dark charcoal color that is close enough to black for this purpose. Paint the entire cab with primer, paying special attention to the nooks and crannies. Those are very hard to cover evenly with sprayed Duratex.
