Plunge Router
doncolga
Plunge Router
#1 Post by doncolga »
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Re: Plunge Router
#2 Post by LelandCrooks »
gone.
doncolga
Re: Plunge Router
#3 Post by doncolga »
LelandCrooks wrote:gone.
I just got it. I talked to the guy...says its brand new Buffalo, been used once and includes looks like about 14 different bits.
Plunge Router.jpg (12.36 KiB) Viewed 1901 times
Plunge Router 2.jpg (13.5 KiB) Viewed 1901 times
Donny Collins
Nordo
Re: Plunge Router
#4 Post by Nordo »
Congratulations Donny :hyper:
Has anyone got any tips or links on how to use a router?
Also are the cheap "Taiwanese/Chinese" ones OK for limited use? i.e. say 4 - 6 cabinets?
What are a good set of starter bits for doing BFM cabinets (DRs and Titans)?
doncolga
Re: Plunge Router
#5 Post by doncolga »
Nordo wrote:Congratulations Donny :hyper:
I've never touched a router before in my life. If this one gets me through my six boxes (OT12's and Tuba 30's) I'll be happy. I've got an outdoor wedding at a local winery on the 5th and it'd be great to have the boxes really cleaned up by then.
Donny Collins
Re: Plunge Router
#6 Post by Tom Smit »
Youtube is full of vids.
Woodworkers, Woodworking ..... Google gave me this ...http://www.google.ca/search?q=router+ti ... =firefox-a
As for bits, 1/2" bottom bearing flush trim, a round-over bit (some like 1/4", some like 1/2"), up-spiral, (down-spiral is also handy). Carbide tipped will go through 18 ga nails.
doncolga
Re: Plunge Router
#7 Post by doncolga »
hey Tom,
Does this one look decent to you?
Donny Collins
Re: Plunge Router
#8 Post by Tom Smit »
Donny, that one is 700 watt (mine is 1320, 2 hp) so it is somewhat under powered. It can work if you have patience and work slowly, paying attention to the motor and the bit and how they sound when it's working, ie, not overloading either of them.
I tried to find Buffalo routers but I wasn't successful.
Re: Plunge Router
#9 Post by Grant Bunter »
Hey Nordo,
I once bought a cheap as chips 115mm angle grinder. XU1 brand from Bunnings, to do one job.
I figured if it failed at $20 I really didn't lose much. Opened the box and it had a spare set of brushes!
I've flogged that poor thing stupid for 8 years now, still haven't got to the second set of brushes.
I'm using Dads Makita non plunge router, haven't used them much myself, so, I bought a set with 1/2 and half round over, trimmer bit (and a nice size 45 degree bit I thought might trim up some bearing edges on drums lol). plus about 6 others bit's for less than $30, seem fine.
With whatever bit you use, disconnect your plug before changing bits. Always beware of where the power cord is as you move around.
Set you depth and do a quick check with a scrap (I found out the hard way, set one too deep and had to get out more bog).
Better to start and find out you've not taken enough than too much.
Your follower bits (with the bearings on the bottom) need something to follow, so if you get to a place where's there's no timber over the edge you'll dig in where you don't want to dig in...
Just take you time and treat it like any other power tool, potentially dangerous :)
Donny, looking good!
As suggested, don't try to work too fast due to your lower rev count. That pack of bits looks very similar to what I bought and they seem to go well enough...
bitSmasher
Re: Plunge Router
#10 Post by bitSmasher »
Tom Smit wrote:It can work if you have patience and work slowly, paying attention to the motor and the bit and how they sound when it's working
Same goes for any cheap tool, if you learn to hear and feel the tool in use you can prolong its lifetime dramatically.
Re: Plunge Router
#11 Post by Tom Smit »
Very true!
subharmonic
Re: Plunge Router
#12 Post by subharmonic »
Donny,
My tips are try your edges on scrap til you get some practice, take your time. Routers can eff up a clean looking cab in a hurry, done it more times than I like to admit, so preplan every maneuver. NEVER go with the bit rotation, ALWAYS push against it, that should be left to right with the wood in front of you and the router between you and the wood
Dan
I need more bass
CW Mcall
doncolga
Re: Plunge Router
#13 Post by doncolga »
subharmonic wrote:Donny,
Dan
Thanks man. Definitely will do lots of scrap before I hit the boxes.
Donny Collins
thekl0wn
Re: Plunge Router
#14 Post by thekl0wn »
When setting a depth-stop, always double check it to make sure it's tight. I've seen the effects of it in a recent build thread on here, and I've done it a few times myself on near-finished items when I was routing to flush-mount items.
This one is a personal preference, but if you use a pattern bit for anything, I like to lay the pattern down, rough trace it, and use a jig/band/scroll saw to take off the big parts, leaving 1/4-1/2" of material for the pattern bit to eat off. Makes the cuts go much smoother and reduces the chances of a kickback.
Good luck and have fun!
Something Witty
doncolga
Re: Plunge Router
#15 Post by doncolga »
I'm off to pick up the router. Woohoo! Which bit will I be using to make the round overs? 1/4 or 1/2 correct..either one OK?
Donny Collins
