TITAN 48
Re: TITAN 48
Thank you for the input. I am listening the advice and saving dollars for wood and other stuff for the build now. The bash plate thet Drey has do really seem appealing , I need to check those out!!
									In the works Titan 48 BFM's
QSC1400, 1 pr fender 112elc,2 pr old jbl g734
numark 1100 mixer
this is all home and outdoor door stuff for personal pleasure.
In the process of buying a real eq and some other equipment
numark 1100 mixer
				Greg Plouvier
Re: TITAN 48
Glad to hear that!gdougherty wrote:I recently switched to some nice Beyma CD drivers and run my rig biamped. I'm now quite happy with the OT12's where I was merely satisfied before.
Greg Plouvier
Re: TITAN 48
I am very happy even with the junk wood and driver I used. I am very excited to build the real ones
numark 1100 mixer
numark 1100 mixer
				gdougherty
Re: TITAN 48
I would avoid things like that in a pro sub myself. Plate amps often have problems cooling in the sun and sub power requirements are often heavy. Seen plenty of plate amps go out on powered speakers which leaves your sub inoperable until you can repair/replace. May take a lot of work if you have to replace with a different model that doesn't fit in the same opening. Sacrificing airtightness on a sub design that's intolerant of leaks is also a possible problem.adrian wrote:Thank you for the input. I am listening the advice and saving dollars for wood and other stuff for the build now. The bash plate thet Drey has do really seem appealing , I need to check those out!!
				gdougherty
Re: TITAN 48
Still need to get them outside and tweak a bit more, but I've been quite happy with the results this far. Frequency response off axis is much smoother vs the melded and the hole in the mids that develops where the 12" starts beaming. Don't know though, the newer phase plug design probably does better there.Greg Plouvier wrote:Glad to hear that!gdougherty wrote:I recently switched to some nice Beyma CD drivers and run my rig biamped. I'm now quite happy with the OT12's where I was merely satisfied before.
- Drey Chennells
Re: TITAN 48
I believe the OP was referring to an outboard plate amp/case..gdougherty wrote: Sacrificing airtightness on a sub design that's intolerant of leaks is also a possible problem.
     "Things happen, but music stays in your blood forever~."  bf
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
						InfraCoustik
				gdougherty
Re: TITAN 48
That eliminates concern about sealing, but makes a plate amp for pro use even less sensible IMO unless you just had a big plate amp laying around.Drey Chennells wrote:I believe the OP was referring to an outboard plate amp/case..gdougherty wrote: Sacrificing airtightness on a sub design that's intolerant of leaks is also a possible problem.
- DJ Higgumz
Re: TITAN 48
+1gdougherty wrote:That eliminates concern about sealing, but makes a plate amp for pro use even less sensible IMO unless you just had a big plate amp laying around.
get a processor like the driverack or behringer and a used 150$ amp off of craigslist. it saves alot of rackspace and weight in the longrun
Building
4 30" T60s
2 19" T60s
1 30" T39
3 Autotubas with GTO804
Bought
2 Dr250s
						Building
4 30" T60s
2 19" T60s
1 30" T39
Bought
2 Dr250s
Re: TITAN 48
I found a nice dbx driverack processor in mint cond. for $300. but I have found all kimds of stuff on craigslist like compressors and limiters and even found 2 ev xeq3 for $48. each just do not know what I need.   I found my wood at Imeca today for $20 pr sheet of 1/2 birch and $30 pr sheet sealed with clear on 1 side. I am pouring a concrete slap behind the house this coming friday so the I will go get the wood for my titans. 3/4 was $40 for a sheet but that is overkill.
numark 1100 mixer
numark 1100 mixer
Re: TITAN 48
That's a pretty good price. It makes me wonder if it has a very thin outer veneer on it because real BB doesn't. Thin venner is no good, ie, it will pull away.adrian wrote: I found my wood at Imeca today for $20 pr sheet of 1/2 birch and $30 pr sheet sealed with clear on 1 side. I am pouring a concrete slap behind the house this coming friday so the I will go get the wood for my titans. 3/4 was $40 for a sheet but that is overkill.
 Also, make sure that the BB is 7 ply.
  Also, make sure that the BB is 7 ply.TomS
						Re: TITAN 48
All the layers were of equal thikness . I looked really good at it and the3/4 was 7 layers.       What does anyone think about the dbx rack processor? Is it a crossover, eq or should i even ask?
numark 1100 mixer
numark 1100 mixer
- Drey Chennells
Re: TITAN 48
Askadrian wrote:All the layers were of equal thikness . I looked really good at it and the3/4 was 7 layers. What does anyone think about the dbx rack processor? Is it a crossover, eq or should i even ask?
 dbx driveracks and behringer dcx2496 are the ubiquitous speaker processors recommended and standard equipment to properly process (crossover,eq,limiter) the signals for bf pro cabs.
 dbx driveracks and behringer dcx2496 are the ubiquitous speaker processors recommended and standard equipment to properly process (crossover,eq,limiter) the signals for bf pro cabs.     "Things happen, but music stays in your blood forever~."  bf
InfraCoustik
						InfraCoustik
- DJ Higgumz
Re: TITAN 48
I would get an all in one like above, because if you have separate ones that increases signal distortion and cable failure
Building
4 30" T60s
2 19" T60s
1 30" T39
Bought
2 Dr250s
						Building
4 30" T60s
2 19" T60s
1 30" T39
Bought
2 Dr250s
Re: TITAN 48
So really the dbx driverack pa processor would do everything for me.
numark 1100 mixer
numark 1100 mixer
- subharmonic
Re: TITAN 48
Limiter\checkadrian wrote:So really the dbx driverack pa processor would do everything for me.
EQ\check
X-over\check
You should be good to go, add amps and speakers.
I need more bass
CW Mcall
						I need more bass
CW Mcall
