TITAN 48
TITAN 48
So I started the 48 build yesterday morning and have plenty of pressboard and decided to build the first 1 out of it before I buy the good stuff and I am very happy with it so far, it is almost half way done. This eneving when I get home I will finish it.
In the works Titan 48 BFM's
QSC1400, 1 pr fender 112elc,2 pr old jbl g734
numark 1100 mixer
this is all home and outdoor door stuff for personal pleasure.
In the process of buying a real eq and some other equipment
numark 1100 mixer
- camrynekai
Re: TITAN 48
LMFAO....Go right ahead...
Facebook Page
More Bass then Fitzmaurice??? Click here
My herd of T48's
Cabs built
14- 24" T48's 3015LF's
6- OTop 2X12's W/Straight array's
4- OTop 12's W/melded array's
2- OTop 12's W/Straight array's
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
- Drey Chennells
Re: TITAN 48
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
InfraCoustik
Re: TITAN 48
Cool, hope the rest of the build goes well.
Just out of curiosity. Why not use the suggested plywood? I'd guess it will be more prone to leaks and the cab might actually rip itself apart over time with pressed wood.
You're talking about this stuff, right?:
Re: TITAN 48
Thats the stuff ! Because I had it to tear up and it was free. So I am using the practice !!
numark 1100 mixer
numark 1100 mixer
Re: TITAN 48
We've started a betting pool on the number of splinters you get.......the over/under is currently at 124.....
- Jon Barnhardt
Re: TITAN 48
lol, recently used that stuff for flooring in my new shop's loft and spent about 30 minutes the next day pulling it out of my hands...Bruce Weldy wrote:We've started a betting pool on the number of splinters you get.......the over/under is currently at 124.....
- camrynekai
Re: TITAN 48
Not to be negative...but all I can see is lots of tooth picks and a shredded driver using that wood. T48's are no joke!...they WILL crack sheet rock at will, a V plated stack of 6 can make one lose control of their bladder if standing to close...not to mention that T48's can make booze dance off the shelf of the bar next door
Facebook Page
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
wounded horse
Re: TITAN 48
Do you run a boarding up company?
Fair play mate. Just wish I had the time to do practice runs.
Re: TITAN 48
After I am done I am just gonna keep it for a model to show the cops that the sound is coming from this except made with real wood .
But no really I am buying the real wood this weekend, I just did it for a mock up to show my lumber guy what we are building, He is my neighbor with the sawmill. I do believe we are gonna use regular plywood but also cover it with cedar planks we cut , should smell really good
numark 1100 mixer
numark 1100 mixer
Re: TITAN 48
Wish we had a bs forum on here for this kind of sh_t! I pulled splinters last nite lol
numark 1100 mixer
numark 1100 mixer
Re: TITAN 48
Ok I got it done yesterday and tried it last nite and with no crossover it sounds great for what it is made of. I screwed a inline car non adjustable cross over to the back of it and it made a lot of difference but still it is a car unit non adj.
I am buying 1 this coming weekend, all in all I am very happy with this toothpick build and after all it was stuff left over from hurricane charlie! After all it was junk wood and we wanted to build it out of scrap first with a junk driver and if there was a problem we could just set it a blaze
I wall loaded it and it did sound good , but I need to get the levels of my mids and highs down but will the crossover do it or do I need a crossover and something else?
I am looking at a rdl stick on series stcx1 or a 2 for a crossover , just no sure of this.
I would like to get my electronics out of the way first..
numark 1100 mixer
numark 1100 mixer
Re: TITAN 48
This is for your stereo, correct? If so, then a Dayton sub plate amp, or Bash, or ....shoot, I forget the other one, will do the cross-over for you and supply the power. The next step up might be a DCX2496 along with a separate power amp.
Re: TITAN 48
Ok, thats what I needed to know.
But after I get my other boxes done i won't be using this box any more
It was just for a first time freebie
numark 1100 mixer
numark 1100 mixer
gdougherty
Re: TITAN 48
I found I needed to apply some EQ to tame the rising sensitivity of the box along with the crossover. I'm crossing mine up around 120 these days though and letting my tops run down to 100Hz. My OT12's start rolling at 120ish so I use the T48 to fill in some there on what really needs it. With a steep slope and an 80Hz crossover you could possibly live without EQ.
I am one of the pickier around here though. I recently switched to some nice Beyma CD drivers and run my rig biamped. I'm now quite happy with the OT12's where I was merely satisfied before.
