4 x Titan 48 24" and 8 x Jack 15 Build (Completed)
				Gregory East
Re: 4 x Titan 48 24" and 8 x Jack 15 Build
That's adventurous. It sounds like you won't be using recommended Eminence drivers? You may need a lot of EQ to get a respectable sound from the Jack15 if they don't have the required rising response in their midrange woofers, and make you drive them harder to get SPL up.
You do nice work.
				bassmonster
Clean builds!
				Gregory East
Very tidy.
I hope that lovely looking ply doesn't have a thin veneer face.
Good work. Those are coming along nicely.
Are you sure you can't find a suitable 12 inch driver locally?  It's true that the Jack 15 goes lower than the Jack 12 or OmniTop 12, but it's not any louder.  When you are running with subs, all that low end extension is wasted because the subs take over.  Thus, you are bringing a bigger box that's not giving you any advantage.
The Jack 15 will be nice for small events where you don't need subs, but for that purpose you only need 2, not 8. If you can find a suitable 12 inch driver, you would be much better off with 8 OmniTop 12 speakers for the big events.
Another thing to think about is your sub-to-top ratio. For 2000 people, you might be a little shy on bass with just 4 T48s. You might want to increase that to 8 or even 16 to keep up with your 8 tops.
If you're are planning on multiple smaller rigs for rental/use, then i guess the jacks will work, but as other have said, once you add a sub, the only thing you need is an ot12. It's a much smaller, lighter cab that will give you everything you need as a top.
I have jack10's and ot12's. I takes about two jack10's to equal one ot12. As for the work, price and size of both, it's almost identical. The jack15 will be much more of a match on the spl as a top, the down side will be the much bigger cab.
From you first post, it sounded like you couldn't get suitable 12 inch drivers locally.  If you can, forget about building more than 2 Jack 15s.  Any situation where you need more than a pair of Jack 15s would be much better served with separate tops and subs.  Build a single pair of Jack 15s as your small rig and then piles of T48s+OT12s as your big rig.
What one hole in one brace and three in the other. That's it it's over. Done messed up good now.
Seriously though Nice work. Should be awesome to listen too in the end.
Joke: why are are you wasting time here then?mickeylau wrote: I need to complete it in another 2 days as my event are nearby.
He was joking here.ewetho wrote:What one hole in one brace and three in the other. That's it it's over. Done messed up good now.
						- Michael Ewald Hansen
Daayumm, that is some fast building man   Looks very nice..
 Looks very nice..
Im pretty sure they wont sound any loud though, on that last picture!
									 Looks very nice..
 Looks very nice..Im pretty sure they wont sound any loud though, on that last picture!
Authorized Builder - Denmark
Looks like a good time to soon be had. Yest the first line was a friendly joke on the last post and was meant to make you smile and laugh. Not a biggie. You will really enjoy them when done I am sure.
BTW.. LOOKING NICE!!!
				bassmonster
Re: 4 x Titan 48 24" and 8 x Jack 15 Build (Completed)
Nice!  Liking the natural finished access panels.
						I think I remember this coming up quite awhile ago. I think the solution was some stronger bracing, but I don't remember.mickeylau wrote: the front panel connected to the panel 6 extension and vibrate very hard, I'm worried about weather it can stand for long period.
