Has anyone used LED worklights or shop lights for a cheap stage wash?
I'd be looking for recommendations for brand (I know I've seen a club that uses these white Menards ones for their outdoor stage, $39 each, and Harbor Freight has some for $25 each).
Also any filters that help with the light? Or maybe I'll just gel them?
These are half the price or less compared to LED lights over at cheaplights, which is why I'm inclined to try them out.
cheap lighting
Re: cheap lighting
I get the feeling I'd be frustrated by work lights.
Anyone have suggestions for lighting a bar band in small spaces?
- Mounting cans or color strips above/below FOH speakers on the stand?
- Colorstrips or cans at the front of the stage?
- etc?
Thanks
- etc?
Thanks
- camrynekai
Re: cheap lighting
MCM 555-11400 on sale now for like 59.00 I have 30 of them at club and they work great.
Facebook Page
More Bass then Fitzmaurice??? Click here
My herd of T48's
Cabs built
14- 24" T48's 3015LF's
6- OTop 2X12's W/Straight array's
4- OTop 12's W/melded array's
2- OTop 12's W/Straight array's
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
Re: cheap lighting
I use ADJ Par 56 LED, but any LED fixture will do based on your budget. Between $70-$100 per fixture is the going rate new. If your lucky you can get them cheaper on ECraigsBayList.
I have used these recently to mount under the top boxes on the tripod stand.
http://www.musiciansfriend.com/pro-audi ... QAodbzRqiw
I also use a piece of PVC pipe (see below)with an inside diameter of roughly the size of the stand between the clamp. This prevents scratches on the stands.
I'll use 1 Par on each side as a wash going across the stage then 1 Par each side set to sound activated crossing the dance floor. That is the best budget light show I have ever seen.
But as always, the more lights the better you sound.
- Attachments
- c.jpg (1.59 KiB) Viewed 1102 times
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
SAC 24 Channel Mixer
SAW STUDIO Recording
- jswingchun
Re: cheap lighting
See this thread if you haven't already. It was very informative.
http://billfitzmaurice.info/forum/viewt ... lit=lights
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
