I have always been impressed by the routered logo's/names on the sides of cabs. Makes them look less DIY, more professional. So I took some scrap ply, printed super large font WH8 on some paper, stuck it to the ply with glue and hit it with the jig saw. Of course I forgot to take the width of the router bit and pattern follow ring into account, so I had to use the center parts as well to not make a proper mess of the "8".
Then try the template on another piece of scrap ply. The shape is not bad, much better than I had expected. But I routed way too deep.
Changed depth to approximately 1 mm (a tad under 1/16" if your mind is not metric). It looks much better at this depth.
Then I screwed the router template to the cab shell and routed away. The logo is on both sides now, so in either wedge position it shows.
Also, note the two small openings left and right. That's where the connectors will go. One left, one right for easy daisy chaining on stage. Not my own idea mind you, someone has mentioned this in the past and it seems like a good idea to me.
Thanks to Dave Perry for allowing me to pick his brain on how to work router templates. Any errors or stupidities in execution are mine.
