Router templates and logo's
#1 Post by AntonZ »
I'm currently building a WH8. I already have one WH8 that performs fine for me, it was built from the older version plans (pre summer 2011 update). Since the newer plans are a considerable update, response may differ more than marginally. I prefer my monitors to EQ equally, don't have time to build two cabs and feel bad about dumping a cab that is working fine for me. So I'm building a new cab from the old version plans. Hence no full build thread. There is one thing I'd like to share though.
I have always been impressed by the routered logo's/names on the sides of cabs. Makes them look less DIY, more professional. So I took some scrap ply, printed super large font WH8 on some paper, stuck it to the ply with glue and hit it with the jig saw. Of course I forgot to take the width of the router bit and pattern follow ring into account, so I had to use the center parts as well to not make a proper mess of the "8".
Then try the template on another piece of scrap ply. The shape is not bad, much better than I had expected. But I routed way too deep.
Changed depth to approximately 1 mm (a tad under 1/16" if your mind is not metric). It looks much better at this depth.
Then I screwed the router template to the cab shell and routed away. The logo is on both sides now, so in either wedge position it shows.
Also, note the two small openings left and right. That's where the connectors will go. One left, one right for easy daisy chaining on stage. Not my own idea mind you, someone has mentioned this in the past and it seems like a good idea to me.
Thanks to Dave Perry for allowing me to pick his brain on how to work router templates. Any errors or stupidities in execution are mine.
Re: Router templates and logo's
#2 Post by DJPhatman »
Will you "engrave" the other cab?
#3 Post by AntonZ »
Yes sir 8)
I intend to make them near identical twins. Going to install grills on both, if I can find some suitable and affordable material locally.
bassmonster
#4 Post by bassmonster »
Nice! :clap:
Scott Brochu
#5 Post by Scott Brochu »
Very professional. :clap:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
#6 Post by Tom Smit »
Thanks for sharing, Anton.
spongebob1981
#7 Post by spongebob1981 »
I'm doing that same thing on my cabs but I found out that, unfortunately, if the ply is of not a great quality, it shows it big time. Forces me to sand the inner part of the letters.
YMMV
"Yep, deep orange" 2xJ10
(other site) 50W DIY Tube Head
"La música es el delirio. Bienvenidos al delirio."
#8 Post by AntonZ »
Same for me. For this cab I'm using poplar. It is nice, straight and light but the routering tends to leave some "threads" at the edges with poplar, more so than with birch I think. Couldn't find any good birch locally this time. Birch smells nicer, too. Curious to see how much the finished cab will weigh compared to the birch WH, and how easily it dents after finishing.
#9 Post by LelandCrooks »
Nice
#10 Post by AntonZ »
Need the extra wedge tomorrow, so I painted and finished the cab today. Installed crossover, damping, handle, sockets (both sides - for easy daisy chaining on stage), driver and wiring. Tested with some music to confirm the wiring and crossover. Then put the cover on.
Grill and corners still to be installed, other than that it is done. I'm glad I tried the routering, quite happy with the result.
#11 Post by Tom Smit »
That looks totally professional to me!
escapemcp
#12 Post by escapemcp »
Anton,
I routed my design onto the slopey front bit of my T30 last night (pics to follow in my thread (see sig below)), but after testing with just 1 coat of Duratex (and a open cell foam roller) on my much deeper test cut, I am unsure if I have routed deep enough on the actual speaker. I just saw that you mentioned that you routed to about 1mm. I have done about half that. Do you reckon it will show through enough?
Many thanks (for both the idea and your help :) )
Aidan
#13 Post by AntonZ »
With a textured paint job that might be a tad shy to show. If I were you I would try this router depth setting on a piece of scrap ply. So use your template on a scrap, same depth for the router, route away, a little quick sanding of the edges and apply your choice of paint finish. If it works, go ahead. If you feel it is too shy, put the template back onto the cab (screw holes not filled just yet, hopefully?) and set the router just a tad deeper. Again, I would first give the adjusted depth setting a quick try on scrap ply. Remember you can always take a little extra away from your cab, but you cannot add back after you have set your router too deep.
Personally, I feel the depth that I have used is just about perfect. I did however not take exact measurements so cannot tell if it was exactly 1mm.
Do bring on the pics once you are happy with the logo. Both before and after applying finish. A little explanation of how you made the template, the font you used, some pics with the template alone, routed but not painted and finished result are always welcome!
byacey
#14 Post by byacey »
I like the full width access panel. Is this a throwback from the earlier plans? This would certainly make it easier to access the crossover board for installation and servicing in the future. I like the scoop handle too; how well are they balanced when carrying? I know there isn't a lot of room for placing them.
T48s
WH8s
SX212
#15 Post by AntonZ »
The full width access panel was in the plans for the previous version indeed. I find it hard enough to install a driver with the full width panel, cannot imagine what it would be like with a smaller opening. The scoop handle is pretty much center of gravity, works fine. Then again, if you intend to repeat this on the new plans, look carefully - dimensions have changed so I don't know if it fits that model. For this build I already had a completed cab available to guesstimate the correct position and it worked fine. I would not use this particular model handle on a birch cab though. The handle is plastic, works on a lighter poplar cab but the full 1/2" birch version might be a tad heavy for this handle.
Having a speakon connector on either side is utterly brilliant. Nobel prize for whomever came up with the idea. I love it for easy daisy chaining on stage.
