Sort of looks like a Jack Lite, except for the tweeter array or comp horn.
http://www.pyleaudio.com/sku/PPM501
It's advertised as a "midrange stage enclosure". It's made out of MDF and weighs 123 pounds!
Here's the spec sheet.
Heavy Duty MDF Construction w/Reinforced Corners
Durable Black Splatter Paint Finish
15'' Driver 2.5'' Kapton VC
Magnet Weight: 90 oz
Ported Enclosure for Added Response
Steel Recessed Handles for Easy Portability
Dual Speakon & Dual 1/4'' Jacks
Binding Post Terminals
Built In Crossover Network 1KHz-5kHz
Power Handling: 250 Watts RMS/500 Watts Peak
Frequency Response: 200-2500Hz
Sensitivity (1w/1m): 105 dB
Impedance: 8 Ohms
Dimensions: 33''W x 25.6''D x 24.2''H
Weight: 123 lbs
The specs are surely inflated. How do y'all think the performance would be on it? At a MSRP at over $500, the Jack Lite is still a far better deal and has much better performance, durability, and value. Plus, the Pyle has no woofer spec sheet, or SPL chart, which makes it an unknown quantity.
