Paint for Plastic Piezos?
loudsubz
#1 Post by loudsubz »
Would model paint work for touching up the piezos? When I glued mine together some glue came out between the joints so I sanded it off and there is some spots that look a little rough and I would like to touch it up. Not sure what is best to stick to the plastic.
Michael Ewald Hansen
Re: Paint for Plastic Piezos?
#2 Post by Michael Ewald Hansen »
loudsubz wrote:Would model paint work for touching up the piezos? When I glued mine together some glue came out between the joints so I sanded it off and there is some spots that look a little rough and I would like to touch it up. Not sure what is best to stick to the plastic.
Model paint should be fine!
http://billfitzmaurice.info/forum/viewt ... zo#p159923
Authorized Builder - Denmark
subharmonic
#3 Post by subharmonic »
I used the rustoleum spray paint made for plastic (it has a pic of cheapo plastic lawn chair on it) followed by modelling spray paint. The rustoleum covered the spot filler way better than the model stuff, just like a primer. Did them back to back, no issues yet.
I need more bass
CW Mcall
SoundInMotionDJ
#4 Post by SoundInMotionDJ »
subharmonic wrote:I used the rustoleum spray paint made for plastic (it has a pic of cheapo plastic lawn chair on it)
This stuff is great. I used it on the piezos, DR port rings, and DR port tubes.
--Stan Graves
10 T39S + 10 DR200 + 1 T48
loudsubz
#5 Post by loudsubz »
Does it also come in a small can so I can use a brush? If not it would be alot of masking or remove the elements from the piezo to paint them.
subharmonic
#6 Post by subharmonic »
Spray paint. I tested on miscut piezos. Barely a trace made it past the phase plug.
I need more bass
CW Mcall
loudsubz
#7 Post by loudsubz »
Ended up using speaker cloth instead. Found some on sale and used a piece of corner molding to keep it taught. Had the wife sew the ends of the fabric on the top and bottom so it looked nice and wont fray.
I still need to paint the white molding black, but I think it looks ok.
#8 Post by Tom Smit »
It sure does look OK!
doncolga
#9 Post by doncolga »
I like the cloth covering ALOT. I've seen a piezo stack for OT15's like that. I may do that with mine eventually.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
J_Dunavin
#10 Post by J_Dunavin »
Really like that!
Drey Chennells
#11 Post by Drey Chennells »
Nice. The cloth grill lends a different feel. I've had some requests for cloth over the 8mm round steel we normally use.
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
#12 Post by AntonZ »
I like the look of the cloth over the piezo's, well done.
loudsubz
#13 Post by loudsubz »
All painted up now, just waiting for the duratex
Drey Chennells
#14 Post by Drey Chennells »
:clap: Really nice!
InfraCoustik
