Having trouble cutting wood like me? Now you can!!
NCcrashman
I know my drill bit device wasn't a "hit" too everyone, but this device WILL BE!! I've having a lot of trouble cutting wood too spec's but this thing is THE coolest!! The reviews I've read are amazing and it truly does the job of a table saw if you don't have one. It is a bit pricey but it does the job of a full-sized table saw for a fraction of the price and no electrician too run a 240 line. This thing will save my bacon!! I hope you guy's like it too!!http://www.eurekazone.com/content/ez-track-system-108
~Patrick~
~Patrick~
"If it's too loud, your too old! What's that? I didn't hear you"
Friends don't let friends use crappy speakers!
Re: Having trouble cutting wood like me? Now you can!!
I have one of these. It works pretty good. My problem is compensating for blade width with my cuts.
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
- Jon Barnhardt
Cut your piece you want to keep on the left side of the track. (if you are right handed) Then the kerf won't matter...Dan30 wrote:I have one of these. It works pretty good. My problem is compensating for blade width with my cuts.
NCcrashman
Off topic, but I've always been curious as to which side of your line too cut. I've always assumed dead middle but someone told me outside too compinsate for the kerf.
NCcrashman
Do you have to use a square to align this thing or does it have something built in? I'm also curious if having excess track hanging off the end matters? I want a bigger track for larger pieces but some pieces are 3' or smaller too.Dan30 wrote:I have one of these. It works pretty good. My problem is compensating for blade width with my cuts.
Thanks for the input!!
~Patrick~
NCcrashman wrote:Off topic, but I've always been curious as to which side of your line too cut. I've always assumed dead middle....
Pick a side, but not dead center. On the workpiece side of the line, you'll have to account for the saw kerf. If you stay on the scrap-side of the line, you don't have to account for the kerf. The saw should be cutting so that your pencil or chalk line is just being grazed by the edge of the teeth. Enough to fuzz up or cut the mark in half. That'll keep you within +/- 1mm.
- Jon Barnhardt
+1Radian wrote:NCcrashman wrote:Off topic, but I've always been curious as to which side of your line too cut. I've always assumed dead middle....![]()
NCcrashman
+1 is right. Thank you very much for the tip!!!!Radian wrote:NCcrashman wrote:Off topic, but I've always been curious as to which side of your line too cut. I've always assumed dead middle....![]()
So does the circular saw sled in the Panel Jig plans, at 1/50 the cost.NCcrashman wrote:it truly does the job of a table saw if you don't have one.
- Jon Barnhardt
+1Bill Fitzmaurice wrote: So does the circular saw sled in the Panel Jig plans, at 1/50 the cost.
But the above, when teamed with the bridge and DIY table, becomes one quick, straight line cutting machine...
