No one is more amazed than I am that I have just completed my T39 box. I have lots of sanding still to do, as well as the wiring...
I am planning to put the x-over inside the speaker chamber, but am wondering how I keep everything from rattling. The big inductor can be screwed down, but how about the other capacitors? Should I glue them down? I have also thought about making the x-over on a little piece of 1/2 or 1/4" plywood that could be screwed or glued down inside the box. I could glue the caps to that... but since I have never done this... not sure how to procede? Hot glue? PL? Some other way of fastening them?
t39 x-over
Re: t39 x-over
That's usually how it's done. Make sure nothing can vibrate.fender3x wrote:I have also thought about making the x-over on a little piece of 1/2 or 1/4" plywood that could be screwed or glued down inside the box. I could glue the caps to that... ?
Sydney
- Frankenspeakers
1/8" hardboard/masonite works pretty good. Zip-ties if you are gonna be swapping components, hot glue is a quick and fairly permanant solution. Use E6000, GOOP, SHOE GOO, or LEXEL if you never want to remove the componants ever again.
