settings on voltmeter when measuring voltage on amp?
osse
#1 Post by osse »
helllo, found this info on the site before but can't find it again.
To avoid the risk of frying my voltmeter, how am I supposed to set it up to measure RMS voltage on amp?
Which connections on the multimeter should I use?
This is the model I have:
Thanks!
Re: settings on voltmeter when measuring voltage on amp?
#2 Post by Tom Smit »
Set the dial to 200 on the Vac scale (Volts, alternating current). The leads are in the proper holes in the picture. Put the red (positive) lead on the + terminal of the amp, and the black lead on the - terminal.
Frederic Gelinas
#3 Post by Frederic Gelinas »
VAC 200. Keep the wires as they are.
Frédéric Gélinas, HF Audio
Authorized Builder
HFAudio.ca
Free tone Generator
Frederic Gelinas
#4 Post by Frederic Gelinas »
Tom Smit wrote:Put the red (positive) lead on the + terminal of the amp, and the black lead on the - terminal.
The polarity (+ and - vs red/black) doesn't matter in that case.
Authorized Builder
HFAudio.ca
Free tone Generator
#5 Post by Tom Smit »
True, that.
