Judgement day Titan 48
Re: Judgement day Titan 48
#31 Post by Bill Fitzmaurice »
baronvonsteve wrote: I'm not sure if you can properly reduce the roller grade with water for proper spraying.
IME there's no substantial difference between the two. I use the Harbor Freight hopper gun with the small tip for two coats to cover, the medium tip for a final spatter coat. Straight, no thinning.
Harley
#32 Post by Harley »
Bill Fitzmaurice wrote:IME there's no substantial difference between the two. I use the Harbor Freight hopper gun with the small tip for two coats to cover, the medium tip for a final spatter coat. Straight, no thinning.
Roller grade?
#33 Post by LelandCrooks »
I've rolled and sprayed both. The spray grade is more controllable when spraying, roller grade more controllable when rolling. The viscosity difference is minimal. But you can do both with both.
Harley
#34 Post by Harley »
LelandCrooks wrote:I've rolled and sprayed both. The spray grade is more controllable when spraying, roller grade more controllable when rolling. The viscosity difference is minimal. But you can do both with both.
Actually, I am so surprised at just how far roller grade goes. I panicked getting that 2nd 1 gal pale from you, and haven't even broken into it yet! The spray grade arrives by ship this week with a bit of luck.
So far I have done 4 J112s and two J110s and still have a bit left in that first pale. Two solid coats on each of those cabs as well.
bigtune
#35 Post by bigtune »
Getting a bit off topic for a sec. I see Bill has updates for Titans and Tubas, I wonder if there's any comparison posted with the old vs new already
Dave Non-Zero
#36 Post by Dave Non-Zero »
The updates are clarified and improved plans, nothing Structural to the cabs.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
bigtune
#37 Post by bigtune »
Final product
slapaddict
#38 Post by slapaddict »
Bill you never cease to amaze me. I received mt t48 & dr250 plans and was wondering about spraying then. :clap: Thanks again everyone for the knowledgable threads. :clap:
David
