I only need a couple of Jacks. I only need a couple of Jacks. I only need a couple of Jacks.
I have Bill's prototype, with the "kickstand" and I am adding a melded array and filters with an all on/alloff by-pass switch. IOW, when the tweeters are on, the filters are used. When switched off, the filters are by-passed.bzb wrote:Any of you bass nerds using a single 110/112 with the little kickstand that Leland sells?
Any other feet or anything on the bottom, or just the rubber caps on the kickstand? Wondering if it stays put on something like a hardwood stage, or if you need the other rubber feet on it. Also, is the angle enough to get the sound up at you?DJPhatman wrote:I have Bill's prototype, with the "kickstand" and I am adding a melded array and filters with an all on/alloff by-pass switch. IOW, when the tweeters are on, the filters are used. When switched off, the filters are by-passed.bzb wrote:Any of you bass nerds using a single 110/112 with the little kickstand that Leland sells?
bzb wrote:Very nice. How close is the composite one to being done?
Monomer wrote:All panels are cut, and the resin just show'd up in the mail today. Expect assembly photos soon.
