It'll be getting a strap handle and the Tripath TA2020 amp on the top. Planning on having a 12V SLA battery for the power source.
bzb wrote:
 *drool drool drool*
   *drool drool drool*
 Running by Ace this weekend.
 .Heh, you could make one J210 and two J110. That way you have a small setup or a louder setupcheapbasslovin wrote:I was originally thinking of making 2 210's, which I could then use for loud or hella loud. I might also then be able to go with one as a bass cab and one as a PA in a pinch. This is still an enticing thought, but hearing that clip with its clarity at such low power makes me wonder if I should go two 110's and a 210 or just emulate the wall'o'jacks pic.
 cheapbasslovin wrote:Or just buy a CD and build one of everything and then decide what I need.
   Do it, do it!
 Do it, do it!Did someone say wall'o'jacks?!?!??!cheapbasslovin wrote:This is still an enticing thought, but hearing that clip with its clarity at such low power makes me wonder if I should go two 110's and a 210 or just emulate the wall'o'jacks pic.
Forgive my ignorance on all things bass (like the fish) guitar... but do you have those wired in series/parallel or are bass heads typically 2-ohm stable? Or are they (gasp) 2 channel?jswingchun wrote:Did someone say wall'o'jacks?!?!??!cheapbasslovin wrote:This is still an enticing thought, but hearing that clip with its clarity at such low power makes me wonder if I should go two 110's and a 210 or just emulate the wall'o'jacks pic.
Some heads are 2ohm stable. Peavey makes a lot of 2ohm stuff and Carvin has some as well. I don't cycle through amps like some do so I don't have a big list of what is 2 ohm capable and what isn't.bzb wrote:
Edit: never mind, I see the XTi up there. What's above it?
cheapbasslovin got it right on the Ashdown. I know you figured it out already, but yes the Jacks are parallel, two per side of the XTI.cheapbasslovin wrote:The top of the rack is a Ashdown RPM-1 EVO II preamp by the look of it.
