OT12 Build
Re: OT12 Build
#16 Post by Bruce Weldy »
AntonZ wrote:I had some screen in a cab I built, different model, but it was in a somewhat similar position. Turned out the moving air made it slap against the wood, in your case where the phase plug sits. That made my cab sound nasty. You may want to add some extra staples around all openings in the baffle to prevent it from hitting into the wood. YMMV, my screen was not as solid as pet screen (which is not available here).
hmmmm.....I wonder if I was to run a bead of superglue around the outline of the phase plug if that would lock it down. The edges are solid with the PL soaked into it.
Good point, thanks.
Re: OT12 Build
#17 Post by Bruce Weldy »
More Pics....
Sides on and tophat covers in place.....
This one's still in the oven.
loudsubz
Re: OT12 Build
#18 Post by loudsubz »
Looking great!!
I feel like mine are taking ages to finish. I have them almost done just need to put together crossover and line the inside.
Re: OT12 Build
#19 Post by Bruce Weldy »
Thanks. Waiting on a part for my router so I can use a template to route out for the jack plate.....Guess I should start working on the piezos.
Mike Taylor
Re: OT12 Build
#20 Post by Mike Taylor »
Bruce,
I would really like to see if you could help me build T48's when I'm ready to do it. I love the quality of your work!
Mike
Re: OT12 Build
#21 Post by Bruce Weldy »
Mike Taylor wrote:Bruce,
Mike
Come by and take a look....I'm spending a lot of time in the garage right now.
bzb
Re: OT12 Build
#22 Post by bzb »
This was the sole reason I decided agains the grill on mine. I was worried about rattling/vibration noises.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
Re: OT12 Build
#23 Post by Bruce Weldy »
I'm planning on putting grills on these and retrofitting the old ones. Any suggestions on what type of grills?
How big of a perforation?
Screen bent on the bottom and top?
Foam?
Do the big box stores carry anything that is appropriate? Or, is it a mail order only item?
doncolga
Re: OT12 Build
#24 Post by doncolga »
Sweetness man...very nice looking boxes. Mine are a little more ragged looking, but they seem nice and sturdy.and I'm about to start working on the piezos too.
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
doncolga
Re: OT12 Build
#25 Post by doncolga »
loudsubz wrote:Looking great!!
+1. I started mine in December.
Donny Collins
Re: OT12 Build
#26 Post by Bruce Weldy »
Piezos done.....
Not as pretty as some I've seen. Glue squeezed out the front side. Is everybody painting them to make 'em look so good? And isn't that a little tough now that you can't take off the backs?
Oh well, I'll put grills on 'em.
Re: OT12 Build
#27 Post by Bruce Weldy »
Got the holes for the jack plates cut out and recessed.
Braces for array also in. Added a filler at the bottom. Didn't like to look of the spaces on top and bottom. I figured if I stack a box on top, it will put the array closer to the one on top.
Re: OT12 Build
#28 Post by Bruce Weldy »
Grill brackets are in.....
And the crossovers are built.
Re: OT12 Build
#29 Post by Bruce Weldy »
While painting can cover up woodworking mistakes, I hate letting go of the bare wood...but it's got to be done. Cabs are now primered with flat black paint. Duratex is coming next.
bzb
Re: OT12 Build
#30 Post by bzb »
Yes on painting the tweets. Haven't gotten any of the crazy glued up ones yet, so not sure what I'll do when that time comes.
Bobby Shively
