Curved Grill WH10
Re: Curved Grill WH10
That is simply beautiful. I hope next time I come to Israel I can see them first-hand.
Carvin BX500, GK MB200, 2 x Jack 10.
Thanks, and you're most welcome...ian wrote:That is simply beautiful. I hope next time I come to Israel I can see them first-hand.
Authorized Builder
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
http://www.boniton.co.il
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
+1.... How long to make the template?Radian wrote:
Built: 2 T48 24" 3015LF, 2 DR250 2510
Planned: 4 T48 18" 3015LF, 4 DR250 2510
- Chris_Allen
Sometimes I wonder why I even bother trying to make mine look good!
Who's Pin?
- Dave Non-Zero
I hate you, but I love you, but I hate you, but I love you, but....
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
That must be the band member... for the rest of the world its "Nid"LelandCrooks wrote:Who's Pin?
That took about an hour IIRC, but that was a one-time investment.jjohnson wrote:How long to make the template?
Doing the logo with the template takes 2-3 minutes.
Authorized Builder
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
I knew this thread would be way cool. Beautiful cab, and thanks much for sharing some of your "tricks" with us!
Albert Einstein
Albert Einstein
Black is Beautiful...
All pilot holes for the different accessories done. Here the ones for the grill:
Bondo repair on all defects and final sanding of the cab's exterior:
Cabs mounted on a square beam for painting. The cabs are positioned symmetrically so rotating the beam is easily done with one hand at 90 deg. increments:
The beam attaches to the cab at the speaker baffle.
The horn is painted with basic black paint. This isn't going to be seen through the foam backed grill:
Textured polyurethane paint is applied to the outer shells, access covers and grills:
Close-up of the grills:
Close-up of the cab:
Closer – up:
Closer – up:
Authorized Builder
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
If could, I would marry your cabs
and the union would be considered Beauties and the Beast.SeisTres wrote:![]()
YAY! I get to be a prince at the end!Bruce Weldy wrote:and the union would be considered Beauties and the Beast.SeisTres wrote:![]()
If could, I would marry your cabs![]()
I've always wanted to be a prince!
Re: Black is Beautiful...
Is there any particular brand here in the states that makes textured polyurethane paint?N.Webber wrote: Textured polyurethane paint is applied to the outer shells, access covers and grills:
