 - this build will go more swimmingly than the last - plus this time I'll be outside and not in the basement.
 - this build will go more swimmingly than the last - plus this time I'll be outside and not in the basement.Unfortunately, once decided to start building and bought all the materials the weather took a turn to the cold/rainy/windy. The next 10 days (and previous 5) are supposed to be one or two of those scenarios so the progress will likely be slow. I've spent the last weekend building their new home in the back of the Xterra. Two 16.5" TAT's should slide in with almost no room to spare side-to-side! (Test fits confirm they SHOULD just fit, Sketchup agrees)
Of course, plans change when you realize what you drew up from memory one day doesn't quite match what the interior is really like...
Replaced the carpet with a solid MDF floor and added storage for the first aid kit and trailer hitch/tow straps as well as a shelf for the amp and crossover. The TAT's will be held in place by the sides as well as brackets in back and a decorative lip bolted to the floor that rests over the front lip of the mouth.
I've cut both sets of side panels and sketched out the lines on all 4 - plus cut out the access cover holes in two of them. (Pics shortly)
Next up, the driver baffles! (Provided when I get home it's not raining...)
