Piezos
Piezos
#1 Post by LelandCrooks »
I finally got in a batch of piezos. Sorted last night to start building some very overdue arrays. I usually pull the driver heads before I start cutting, it's just easier. Well, they've started gluing the cone in place. I randomly selected a half dozen or so and they're all glued.
No more rotating the driver heads, at least on this batch. I destroyed 4 of them to see if it could be pried loose. I have another 1k coming in next month. I'll check them when they get here. It will also make repair of a bad one difficult, but not impossible.
Re: Piezos
#2 Post by Bill Fitzmaurice »
LelandCrooks wrote:I finally got in a batch of piezos. Sorted last night to start building some very overdue arrays. I usually pull the driver heads before I start cutting, it's just easier. Well, they've started gluing the cone in place. I randomly selected a half dozen or so and they're all glued.
That's not a bad thing per se, if it makes sealing them unnecessary.
Re: Piezos
#3 Post by LelandCrooks »
Hadn't thought about that. Good point.
For repair I think you'd just have to pull the element off, then hot glue it onto the cone of the repaired driver.
SeisTres
Re: Piezos
#4 Post by SeisTres »
Does this mean that if there is some debris from the horn material that we won't be able to take it out? I don't have any extra piezos at the moment and it's been so long since i've built my arrays that i have no idea how they're put together.
But since I don't rotate the covers, I think i'll prefer it if I ever get my dr's build started since all that sealing is really something that I would rather not do.
Mhh, I wonder if the ones PE will be getting will also be like this? I got a batch of them for future builds (Of course, SLA pros to go with the four t18's :hyper: ($4 per driver? why yes, thank you, I'll take 8 :mrgreen: (jeez I need to stop with the thought-interrupting-parenthesis)))and if a piece of plastic is rattling around the whole time this will seriously be a game killer.
Re: Piezos
#5 Post by LelandCrooks »
PE's will be identical, we both buy direct from Goldwood.
No you won't be able to get debris out except for from the front.
Buy extras.
I think you could pull one apart by opening it far enough to get an xacto knife in to cut the ceramic away from the cone. Then hot glue it back in place.
Re: Piezos
#6 Post by Bruce Weldy »
How about just putting some masking tape over them while working with 'em?
DaveK
Re: Piezos
#7 Post by DaveK »
Non-removable elements will make it very hard to spray paint them without getting paint on the cone. No more cool colored arrays :-(
Harley
Re: Piezos
#8 Post by Harley »
DaveK wrote:Non-removable elements will make it very hard to spray paint them without getting paint on the cone. No more cool colored arrays :-(
Buy one on those circular punches they use for cutting holes in gaskets, slightly bigger than the size of the piezo hole.
Then get some 1/2" - 1" thick foam and punch out some plugs and just pop these into the hole before spray-painting.
djtrumptight
Re: Piezos
#9 Post by djtrumptight »
Or you could use masking tape balls to block the paint from the getting into the tweeter as Bill suggested,or you could do like i did and trace around a penny,cut out the circles and lodge them down into the tweeter to keep the paint out.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
BoostFab
Re: Piezos
#10 Post by BoostFab »
LelandCrooks wrote: Well, they've started gluing the cone in place. I randomly selected a half dozen or so and they're all glued.
did you try melting the glue with a heat gun ?
Re: Piezos
#11 Post by LelandCrooks »
No, but that's a pretty good idea.
DaveK
Re: Piezos
#12 Post by DaveK »
Are the cones still prone to detaching from the piezo driver? That was a problem with the old ones, but they could be fixed with a drop of glue. If the backs are now sealed, loose cones are a lot harder to fix.
Re: Piezos
#13 Post by LelandCrooks »
The cones themselves are glued at the edges. You can only pull the assembly out the length of the leads to the ceramic disc
WB
Re: Piezos
#14 Post by WB »
LelandCrooks wrote:I destroyed 4 of them to see if it could be pried loose. I have another 1k coming in next month.
BADASS
:clap:
