omnitop12 first build!
philbill
Re: omnitop12 first build!
#31 Post by philbill »
oh right ok, could it make a hugely noticeable difference? as i said i will try and reduce the amount that it shows anyway, but i just hope it doesnt make to much of an impact on the sound
#32 Post by Bill Fitzmaurice »
philbill wrote:oh right ok, could it make a hugely noticeable difference?
Probably not.
lincsoldbird
#33 Post by lincsoldbird »
Hi wellcome to the forum.
I got my tweeters from blue aran, dirt cheap when you buy 44. I think they came down to 70p each, got a couple of dudes but at that price you can get extra.They are only cheap chinese ones but i think they sound ok with a bit off EQ!
built 4 T30 24in BP102 now sold 2 DR280
2 speakerplans 1850, 2 MT102 ,2 X15, 1 G sub now sold
2 T60,s Built plus 4 DR280,s in the build
philbill
#34 Post by philbill »
i'm guessing they are the skytronic ones? the general consensus on them was that they aint so good! what did you build with them?
lincsoldbird
#35 Post by lincsoldbird »
Two DR280 melded array. In defence off them I do have 200 pound plus compression drivers in the MT102,s to compare with them and i,m happly for the money! :hyper:
The Goldwood ones may be better, I do,nt know not tryed them.
philbill
#36 Post by philbill »
yeah i may just roll with the cheaper ones, as i can get enough to do the build plus spares for around 40 quid
lincsoldbird
#37 Post by lincsoldbird »
Let us know what you think. Do,nt forget to eq them if going active.
philbill
#38 Post by philbill »
yeah i will do, still need to get some eq. I should probs get the behringer DEQ unit but am i alright to go with just a normal 31 band eq? to save some cash
Dave Non-Zero
#39 Post by Dave Non-Zero »
If they are anything like the cheap piezos I've got, you will need to take out more5k than a 31 band eq can manage. :(
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
philbill
#40 Post by philbill »
ah right thats not so good, can you get some 31 band eq's that have more db reduction than others?
If not if i got the DEQ would that compensate enough?
lincsoldbird
#41 Post by lincsoldbird »
Just get the the berry drive rack that should cope. Nota bad price at 200 pounds,and you get three channel crossover as well.
philbill
#42 Post by philbill »
yeah i have the dcx unit already for the limiters and crossovers. do you mean get the deq unit? or that the dcx will suffice?
philbill
#43 Post by philbill »
Some more pics!
As you can see i use very crude methods of clamping! this is because i only have one clamp! If i attempt a titan build in the future i guess i will have to invest! Oh and i only have a jigsaw, some hand saws, a couple of hand files, sandpaper and a plane.
#44 Post by Tom Smit »
Good job, so far, though.
IanChad
#45 Post by IanChad »
I've built a couple of Jack 110s that have short flat arrays. I used the Pulse piezos from CPC Farnell.
The speakers sounded way better than the Wharfedale Titans that I had even when just using the graphic in my PA mixer amp to EQ.
I'm just down the M56 from you, near Knutsford. PM me if you'd like to come and here them.
2 X J110 - DLII2510
