Basement Disco System
Re: Basement Disco System
I have my two 30" T48s setup for music in my basement rec room area which is about 1000 sq ft and I think the bass FEELS perfect!
Charles Warwick
+10,000,000Bill Fitzmaurice wrote:Very much so with the electronics. Avoid using pro amps, they cause more problems than they cure and don't work any better than consumer grade gear.BumpyJ wrote: Is it true that mixing pro audio with HT can get challenging maybe even tricky?
Oh god yes, this is so true. I still have issues trying to properly get my xti 2000 to run my ht sub. I've just given up and stuck with my basic sub amp.
But bear in mind, it's not impossible but requires a good understanding, extra gear, and extra effort.
- Dave Non-Zero
Sorry, I have absolutely zero experience with HT. Why is this?
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Titans belong in a basement
I have my 400ish sq/ft basement setup with 2 X T39 and soon to have 2 X Otop12
Doug C,
The Titans sound good down there? I had another idea to do maybe 4 18" T48's for a bit more extension.
Is is true that the T48's will reach as low as 32hz with enough in the stack before the driver starts to "unload"? Proper terminology?
Maybe I am way off on that.
Haven't yet found out if this is going to be HT and Disco use.
Build a Table Tuba. Basically the same size as a T30, but uses an inexpensive 8" (or 10", if you can find one with appropriate specs), and goes to 30Hz no problem. Heck, for 18-30", build a dual loaded TT!BumpyJ wrote:Doug C,
Charles Warwick
Groups of less than four cabs should be high-passed at 40 Hz. With four cabs or more 35 Hz is acceptable.BumpyJ wrote:I had another idea to do maybe 4 18" T48's for a bit more extension.
You can fudge the HP a little if you limit the power going to them, but you really shouldn't have to fudge the design; you should chose a different sub if that's what you are looking for.
But bear in mind also a stack of 4 18'' T48's is going to be huuuuge. about the size of two chest freezers, 8 feet long, 3 feet high, 4 feet deep? Would you even have that much room in one spot?
Hey, I've got a good idea if you want to do that though, stand them upright, line them up, and then slap a bar top over them
Except then you'd never be able to hear drink requests, and whoever gets to man the bar will be deaf by the end of the night.
+1, although I'd suggest a couple dual loaded to even out room nodes and make sure you can reach earsplitting volume with ease.DJPhatman wrote:Build a Table Tuba.
Was going to get in and take pics today but woke up to over a foot of snow here in Calgary,, so not going anywhere today. No pics yet.
I will post them as soon as I get them.
Thanks again guys
Jordy
Thanks again guys
Jordy
I have just been advised that this will be used for HT also.
Which seems as though it will change things a bit as I was also informed that they want Karaoke to be possible and have a DJ booth and have the ability to run tracks with an IPad when a DJ isn't present.
Should be interesting.
lincsoldbird
If your going to run a ipad any old speakers will do. Come on it got to be flac or wav format or your wasting your time! Do Bill,s speakers justice.!
built 4 T30 24in BP102 now sold 2 DR280
2 speakerplans 1850, 2 MT102 ,2 X15, 1 G sub now sold
2 T60,s Built plus 4 DR280,s in the build
Hey guys any idea why an JPEG won't upload here? I am trying to upload my pics and keep getting an invalid file message.
Use a web hoster. Picasa is where I'm at.BumpyJ wrote:Hey guys any idea why an JPEG won't upload here? I am trying to upload my pics and keep getting an invalid file message.
Too big?BumpyJ wrote:Hey guys any idea why an JPEG won't upload here? I am trying to upload my pics and keep getting an invalid file message.
Good morning guys,
I chanced the blizzard and made it over to get my initial pics taken. The systems priority is going to be for the disco 1st and UFC/HT 2nd. He was even talking about having a little Bose for HT. I am not a big fan but, I respect his wishes. If I can however create a cost effective system that can do both with the above priority taken into account with ample headroom present for the wildest possible disco nights than that is a possibility.
The pic with the stairwell is going to be changed and expanded fairly soon, but those measurements are not yet known. Regardless there may be a way to tuck a couple bassbins underneath the stairwell with ample room for cab width.
More pics to come.
Thoughts?
Thanks
Jordy
More pics to come.
Thoughts?
Thanks
Jordy
I think you're thinking correctly.
If it was me I'd build do 2 x SLAs and 2 TTs or THTs put in the spots you're showing. At full proper amplification you won't be able to hear each other speak without screaming in ears....which is "loud enough" IMO. Don't bother with surround sound or Bose or any of that. Rock out a 2.1 HT with killer bass. Nobody will be complaining.
