Titan 39 20" Wide 12" Sub Build (Completed)
Re: Titan 39 20" Wide 12" Sub Build (Applied Duratex)
Flaky usually means it didn't bond to that spot.  Typically on bondo.  Let it cure fully, 7 days.  Scrape that spot, then sand it so it doesn't have edges, reapply.  It does take some time to blend it in.
Thanks Harley.
Thanks Leland...I will let it cure before I do anything else.
Titan 39 Build
http://billfitzmaurice.info/forum/viewt ... 30&t=13717
Titan 39 Build #2
http://billfitzmaurice.info/forum/viewt ... 30&t=14458
Titan 39 Build #2
So I purchased a Crown xti 2000 amp and it was delivered last week.  I downloaded the software, and via my laptop, set my cross over points (45hz and 100hz).  It was very cool being able to use a laptop to change settings on a "mobile" amplifier.
By the way, I chose the 48db crossover which I believe means a sharper cutoff. Was it smart to utilize that one?
So I used the Titan 39 on one channel of the amp and my Peavey 15inch cab on the other. I turned it up and it sounded very nice and clean but the Titan seemed a little low. I checked the multimeter and it only read 7-12 volts. I had to triple check it because once again I was impressed by the sound and assumed I had more power going to it.
So I took the Titan off and turned up some gains to where the multimeter was reading in the 20-25 volt range. I connected the Titan 39 back up and Holy Shit it sounded awesome and loud.
I know the Titan with a 3012lf can take voltage in the 50's and Bill says to be safe stay in the 40's so I stayed in the 20's for about 15 minutes listening to different songs. This thought kept coming to mind "man, this is only a 12" speaker?!?!".
So I said let me try voltage in the 30's. The Titan really came to life at this point. It sounded really really good, clean and loud...the entire neighborhood agreed.
I will get into more detail about how happy I am with this subwoofer but for now this is good.
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
Build a second one, and then V-plate the!
Outstanding! Another happy builder!
For you next build, I recommend a top with the melded piezo array
Hell yeah. I'm in the process of purchasing a table saw in order to start a new build for another Titan 39.DJPhatman wrote:Build a second one, and then V-plate the!
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
Re: Titan 39 20" Wide 12" Sub Build (Completed)
Ok, I have started the new one.
Do I create a new thread or continue here?
I'm leaning more towards a new thread and referencing my first build in my signature.
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
Yeah, I'd start a new thread.  So, I'm thinking you found a table saw?!  What did ya get?
2 OT12's 2512 CD
2 OT12's 2512 Melded Array
4 Titan 39's 30" 3012LF
4 Titan 39's 20" 3012LF
6 Wedgehorn 8's
1 Wedgehorn10
2 AutoTuba's 18" w/MCM 8"
https://www.facebook.com/pages/LSW-Lana ... 080?ref=hl
						2 OT12's 2512 CD
6 Wedgehorn 8's
1 Wedgehorn10
A $300 Craftsman for $208.Spoon wrote:Yeah, I'd start a new thread. So, I'm thinking you found a table saw?! What did ya get?
I still used a circular saw for the first approx cuts. The table works nice for the angle cuts.
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
